is there any way to install macOS Catalina in HFS+ format?
armenio
Dell 7348
i7-5500U
HD Graphics 5500
is there any way to install macOS Catalina in HFS+ format? Like High Sierra avoid 'apfs'
Or some solution for trim on ssd not apple oem?
Firstly, i would like to know why do you want to use HFS+ in Catalina?
:ROFLMAO: Sorry, i am wrong. I mean 'Mac OS Extended (Journaled)'
Yes, it's available. But that means HFS+ ;)
Do you want the other drives in HFS+ or the system drive?
I would like (if possible) to install the system (10.15) on 'Mac OS Extended (Journaled)' filesystem format, 'natively', without having to make a carbon copy or anything like that
When at Disk Utility, you can select Mac OS Extended (Journaled) instead of APFS. That should work.
this does not work, it forces the creation of the partition in APFS.
I'll have to check. If there's any solution, i'll write the guide.
lucadita
