Hello from Russia
what i should type in boot-args? i have nvidia gtx 1060
nvdisable=1 to disable the NVIDIA GPU during the installation phase.
so i maked efi with guide and i have error while booting to macos:
78:781 00:023 AAPL: #[EB|RPS] 0 0 0
78:802 00:021 AAPL: #[EB.OPT.LXF|F] <"\\System\\Library\\CoreServices\\com.apple.Boot.plist">
78:824 00:021 AAPL: #[EB.LD.LF|IN] 0 1 <"\\System\\Library\\CoreServices\\com.apple.Boot.plist"> <"0">
78:845 00:021 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"\\System\\Library\\CoreServices\\com.apple.Boot.plist">
78:867 00:021 AAPL: #[EB.OPT.LXF|LF!] Err(0xE)
78:927 00:060 AAPL: #[EB.OPT.LXF|F] <"Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist">
78:949 00:021 AAPL: #[EB.LD.LF|IN] 0 1 <"Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist"> <"0">
78:990 00:041 AAPL: #[EB|KF] <"">
79:011 00:021 AAPL: #[EB|MBA:CL] <"">
79:033 00:021 AAPL: #[EB|MBA:NV] <"-v keepsyms=1 slide=128">
79:054 00:021 AAPL: #[EB|MBA:KF] <"">
79:075 00:021 AAPL: #[EB|MBA:OUT] <"-v keepsyms=1 slide=128">
79:096 00:021 AAPL: #[EB|LOG:VERBOSE] 2026-04-06T15:10:42
79:118 00:021 AAPL: #[EB.CSR.S|VAR] 0x00000067
79:139 00:021 AAPL: #[EB|OPT:BM] 0x821002
79:161 00:021 AAPL: #[EB.OPT.LXF|F] <"\\System\\Library\\CoreServices\\PlatformSupport.plist">
79:182 00:021 AAPL: #[EB.LD.LF|IN] 0 1 <"\\System\\Library\\CoreServices\\PlatformSupport.plist"> <"0">
79:208 00:025 AAPL: #[EB|WL] 0 0 0x01 0x01 48 0x0E
79:229 00:021 AAPL:
79:250 00:020 AAPL: ***********************************************************
79:271 00:021 AAPL: This version of Mac OS X is not supported on this platform!
79:293 00:021 AAPL: ***********************************************************
79:314 00:021 AAPL: Reason: Mac-F4208DC8
79:335 00:021 AAPL: #[EB|STOP] 0x11
79:358 00:023 AAPL: #[EB|H:IS] 0
79:380 00:021 AAPL: #[EB.G.CS|-?] Ok(0)
79:442 00:062 AAPL: Displaying boot failure graphic for 10 seconds...
89:465 10:023 AAPL: #[EB|WL] 0 0 0x01 0x03 48 0x0E
89:486 00:021 AAPL: #[EB|EXIT]
89:508 00:021 AAPL: #[EB|LOG:EXIT] 2026-04-06T15:10:52
89:529 00:021 OC: Boot failed - Aborted
89:550 00:021 OCB: StartImage failed - Aborted
Why are you using EnableWriteUnprotector and RebuildAppleMemoryMap together? You should disable the latter one.
Ensure you're installing Sonoma and not Tahoe as iMacPro SMBIOS support was removed.
So I installed macos 12 and make opencore Legacy Patcher to work my gtx 1060. It's laggy if there any fix for that?
Did you patch the Graphics?
See limitations here:
i make it all and what next?
Dartkill
