Hello from Russia
TrueKris
ASUS P8H61-M LX2
Intel Core I7 3770
NVIDIA GeForce GTX 1060 3GB
  2. OpenCore (Legacy)
  3. Windows Phone
  4. Other
Hello from Russia! I'm trying to solve a problem with the SSDT-CPU-PM. I can't generate the file because I'm on Windows 11 and the script is only for MacOS.
Hello and Welcome to EliteMacx86!
You can simply block the OEM SSDTs and then install macOS. Once macOS is installed, you can generate the SSDT.
can you help with config.plist? i make it with oc simplify. i having black screen with "_" in opencore bootloader
Why not! If you stick to the instructions, you can get it working. Before checking EFI, could you please confirm what macOS version are you trying to install?
i trying sonoma
Your EFI is not as per the guide. You should from here:
like that? -v alcid=1 debug=0x100 keepsyms=1 ipc_control_port_options=0 revpatch=sbvmm
so i maked efi with guide and i have error while booting to macos:
78:781 00:023 AAPL: #[EB|RPS] 0 0 0
78:802 00:021 AAPL: #[EB.OPT.LXF|F] <"\\System\\Library\\CoreServices\\com.apple.Boot.plist">
78:824 00:021 AAPL: #[EB.LD.LF|IN] 0 1 <"\\System\\Library\\CoreServices\\com.apple.Boot.plist"> <"0">
78:845 00:021 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"\\System\\Library\\CoreServices\\com.apple.Boot.plist">
78:867 00:021 AAPL: #[EB.OPT.LXF|LF!] Err(0xE)
78:927 00:060 AAPL: #[EB.OPT.LXF|F] <"Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist">
78:949 00:021 AAPL: #[EB.LD.LF|IN] 0 1 <"Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist"> <"0">
78:990 00:041 AAPL: #[EB|KF] <"">
79:011 00:021 AAPL: #[EB|MBA:CL] <"">
79:033 00:021 AAPL: #[EB|MBA:NV] <"-v keepsyms=1 slide=128">
79:054 00:021 AAPL: #[EB|MBA:KF] <"">
79:075 00:021 AAPL: #[EB|MBA:OUT] <"-v keepsyms=1 slide=128">
79:096 00:021 AAPL: #[EB|LOG:VERBOSE] 2026-04-06T15:10:42
79:118 00:021 AAPL: #[EB.CSR.S|VAR] 0x00000067
79:139 00:021 AAPL: #[EB|OPT:BM] 0x821002
79:161 00:021 AAPL: #[EB.OPT.LXF|F] <"\\System\\Library\\CoreServices\\PlatformSupport.plist">
79:182 00:021 AAPL: #[EB.LD.LF|IN] 0 1 <"\\System\\Library\\CoreServices\\PlatformSupport.plist"> <"0">
79:208 00:025 AAPL: #[EB|WL] 0 0 0x01 0x01 48 0x0E
79:229 00:021 AAPL:
79:250 00:020 AAPL: ***********************************************************
79:271 00:021 AAPL: This version of Mac OS X is not supported on this platform!
79:293 00:021 AAPL: ***********************************************************
79:314 00:021 AAPL: Reason: Mac-F4208DC8
79:335 00:021 AAPL: #[EB|STOP] 0x11
79:358 00:023 AAPL: #[EB|H:IS] 0
79:380 00:021 AAPL: #[EB.G.CS|-?] Ok(0)
79:442 00:062 AAPL: Displaying boot failure graphic for 10 seconds...
89:465 10:023 AAPL: #[EB|WL] 0 0 0x01 0x03 48 0x0E
89:486 00:021 AAPL: #[EB|EXIT]
89:508 00:021 AAPL: #[EB|LOG:EXIT] 2026-04-06T15:10:52
89:529 00:021 OC: Boot failed - Aborted
89:550 00:021 OCB: StartImage failed - Aborted
Pumpky
