Hello from Russia
TrueKris
ASUS P8H61-M LX2
Intel Core I7 3770
NVIDIA GeForce GTX 1060 3GB
  2. OpenCore (Legacy)
  3. Windows Phone
  4. Other
Hello from Russia! I'm trying to solve a problem with the SSDT-CPU-PM. I can't generate the file because I'm on Windows 11 and the script is only for MacOS.
Hello and Welcome to EliteMacx86!
You can simply block the OEM SSDTs and then install macOS. Once macOS is installed, you can generate the SSDT.
can you help with config.plist? i make it with oc simplify. i having black screen with "_" in opencore bootloader
Why not! If you stick to the instructions, you can get it working. Before checking EFI, could you please confirm what macOS version are you trying to install?
i trying sonoma
Your EFI is not as per the guide. You should from here:
like that? -v alcid=1 debug=0x100 keepsyms=1 ipc_control_port_options=0 revpatch=sbvmm
JTHaunter
