Please help access i76700HQ intel HD530 Graphics for Opencore EFI Ventura USB installer
Sabotender
Unknown Clevo Laptop Daughterboard!
intel Core i7 - 6700HQ @2.59 GHz
Nvidia Geforce GTX 970M
10.13.x
I have created the foundation USB installer for MacOS Ventura 13.0 22A380 using the createinstallmedia .
I have access to the EFI volume for the USB drive, and have added the bare minimum, and with suggested kexts that are likely compatible for my hardware using Opencore 1.04 from github...
I am uncertain if I could import the compiled DSDT etc files from my High Sierra EFI, but the iGPU is absolutely compatible with Ventura , but I do not know/comprehend the problem configuration in order to directly access the internal intel HD530.
Based upon cited references, it is even possible for me to receive full graphics acceleration, which is exciting. It seems that I may need to fake it into being interpreted as a different but compatible iGPU.
Several years ago, I recall (vaguely) using a similar method before having installed the Web drivers for High Sierra.
Please, would any of you have the information needed, in order to get this to work for my setup?
Thanks for reading my thread. Your responses are always appreciated.
So, this is mildly frusturating, but GenSMBIOS is broken. I have tried using it on Windows (with its batch file) and on my original macbook with that same network connection error. I need to find a method of filling in the SMBIOS section in the Opencore config.plist file without it, manually, because Its just a bit too much to rely upon someone else's server problems when your internet connection is just fine.
Also there doesn't seem to be any direct translation between network hardware models, and device-id. For example, my intel HD530, who knows what that translates to, because its for Skylake gen which needs to be faked for Kaby Lake intel HD 630 graphics, which is compatible for Ventura.
Dunno if anyone compiled that common Hardware ID and Device ID for Opencore.
My Ventura USB installer is almost ready, so close.
I've been at this for several weeks and nogo.Im not sure what info is needed in order for any of this to make enough sense to possibly gain a reply, but my EFI volume has been attached: all I get for now, are instant reboots from Opencore Bootloader, after selecting install macos Ventura. My various Opencore logs have been attached with it though.
you may notice that I have several config.plist files, this is simply because I wanted to keep track of changes, and so I could roll back to the original.
I followed the general boot instructions to get my hardware to boot, including killing the completely incompatible Nvidia GPU.
Thank you for your continued attention to my thread.
Some of those errors did mot make sense to research via search engine. I mirrored most of the settings from my High Sierra install, namely BIOS data, etc. One thing I recall which might be a reason why I cannot boot to installer, a user here once before helped me fix my P and C states,Which was cool. Shame Opencore cannot use FSDT/SSDT because the data there is how I got several devices to work, including my built in card reader.
As far as my USB, I captured my ports using that Windows tool, and imported it into my setup..
Please attach your EFI and BIOS settings to check. Most of the Clevo Laptops have IGPU factory disabled as these are meant for high performance that uses dGPU.
Better you start with the macOS version that has native support for SKL IGPUs.
Your EFI is not as per the guide. Problems are expected!
seph3421
