- May 11, 2023
- Asrock Z790 PG Riptide
- I7 13700k
- Sapphire Radeon Rx580 8Gb
- 15.x
- Mac Pro
Attach your EFI to check!Hello, I have a hackintosh with this system: I7 13700K, Asrock Z790 PG Riptide, Sapphire Radeon RX 580 8G, WD SN850X SSD and I'm using the latest release of Sequoia. Sometimes, however, when I restart or boot up, but not always, it gives me this error. Can you please help me? Thanks.View attachment 9967View attachment 9968
The SSD you're using is a bad choice for boot drive. Plus, your EFI is not as per the guide and problems are expected.Ok, thanks, I also use another Samsung 990 Pro 1TB NVMe SSD with Win11 and an 8TB Seagate Ironwolf Pro data HD for vst or Logic Pro libraries.
Adjust the changes in the EFI as per the guide.OK, so aside from replacing the SSD (which brands), how do I fix the EFI? Thanks
