- Jan 12, 2026
- Dell G15
- Ryzen 5 5600H
- Ryzen 5 5600H
- 15.x
- iMac Pro
I have dell g15 5515 (RTX 3050 4GB + AMD Cezanne Radeon Vega Mobile Series, 5600H) with linux (arch btw), followed the https://github.com/kholia/OSX-KVM, and got a working setup, but purely on cpu, which is good enough, but It would be better to have a little smoothness, so thought of trying out GPU passthrough with VFIO.
I think I am paritally successful, but then what? I am stuck here.
I am using the virtual frame buffer, how do I make the GPU get used, how do I attach a display to it? virtually (or physically? if possible, but its a laptop with IGPU)
config.plist : https://pastebin.com/xm8LiPPU
slightly modified OpenCore-Boot.sh:
MY_OPTIONS="+ssse3,+sse4.2,+popcnt,+avx,+aes,+xsave,+xsaveopt,check"
# This script works for Big Sur, Catalina, Mojave, and High Sierra. Tested with
# macOS 10.15.6, macOS 10.14.6, and macOS 10.13.6.
ALLOCATED_RAM="8192" # MiB
CPU_SOCKETS="1"
CPU_CORES="4"
CPU_THREADS="8"
REPO_PATH="."
OVMF_DIR="."
# shellcheck disable=SC2054
args=(
-enable-kvm -m "$ALLOCATED_RAM" \
-cpu Haswell-noTSX,kvm=on,vendor=GenuineIntel,+invtsc,vmware-cpuid-freq=on,"$MY_OPTIONS"
-smp "$CPU_THREADS",cores="$CPU_CORES",sockets="$CPU_SOCKETS"
# -cpu host,kvm=on,+invtsc,topoext=on \
# -smp cores="$CPU_CORES",threads="$CPU_THREADS",sockets="$CPU_SOCKETS" \
# -cpu host,kvm=on,"$MY_OPTIONS"
-machine q35
-device qemu-xhci,id=xhci
-device usb-kbd,bus=xhci.0 -device usb-tablet,bus=xhci.0
# -smp cores=4,sockets=1,threads=1
# -device usb-ehci,id=ehci
# -device usb-kbd,bus=ehci.0
# -device usb-mouse,bus=ehci.0
# -device nec-usb-xhci,id=xhci
# -global nec-usb-xhci.msi=off
# -global ICH9-LPC.acpi-pci-hotplug-with-bridge-support=off
# -device usb-host,vendorid=0x8086,productid=0x0808 # 2 USD USB Sound Card
# -device usb-host,vendorid=0x1b3f,productid=0x2008 # Another 2 USD USB Sound Card
-device isa-applesmc,osk="ourhardworkbythesewordsguardedpleasedontsteal(c)AppleComputerInc"
-drive if=pflash,format=raw,readonly=on,file="$REPO_PATH/$OVMF_DIR/OVMF_CODE.fd"
-drive if=pflash,format=raw,file="$REPO_PATH/$OVMF_DIR/OVMF_VARS-1920x1080.fd"
-smbios type=2
-device ich9-intel-hda -device hda-duplex
-device ich9-ahci,id=sata
-drive id=OpenCoreBoot,if=none,format=qcow2,file="$REPO_PATH/OpenCore/OpenCore.qcow2"
-device ide-hd,bus=sata.2,drive=OpenCoreBoot
-device ide-hd,bus=sata.3,drive=InstallMedia
-drive id=InstallMedia,if=none,file="$REPO_PATH/BaseSystem.img",format=raw
-drive id=MacHDD,if=none,file="$REPO_PATH/mac_hdd_ng.img",format=qcow2
-device ide-hd,bus=sata.4,drive=MacHDD
# -netdev tap,id=net0,ifname=tap0,script=no,downscript=no -device virtio-net-pci,netdev=net0,id=net0,mac=52:54:00:c9:18:27
-netdev user,id=net0,hostfwd=tcp::2222-:22 -device virtio-net-pci,netdev=net0,id=net0,mac=02:f4:a1:07:3a:0a
# -netdev user,id=net0 -device vmxnet3,netdev=net0,id=net0,mac=52:54:00:c9:18:27 # Note: Use this line for High Sierra
-monitor stdio
# -device vmware-svga
-vga qxl \
# -device ramfb \
-device vfio-pci,host=06:00.0,multifunction=on,x-vga=on \
-device vfio-pci,host=06:00.1 \
# -device qxl-vga,vgamem_mb=512
-serial file:/tmp/vm-serial.log
# -display none \
# -device virtio-vga,ram_size=512M
# -device vmware-svga,vgamem_mb=128 \
# -device ramfb
# -vnc :1 -k en-us
# -device vmware-svga \
# -spice port=5900,addr=127.0.0.1,disable-ticketing=on
qemu-system-x86_64 "${args[@]}"
