Dell OptiPlex 5080 i7 10700
Your EFI is not as per the guide and the problems are expected.
Here are a few issues:
- Remove all the OEM DSDT and SSDTs as they are loaded by defaults unless blocked/dropped.
- Use the standard set of SSDTs for CML.
- Remove ResetLogoStatus
- Your hardware has Intel IGPU. Why are you renaming the model to be Radeon Pro 5700XT?
-The framebuffer patching isn't enabled as well.
- Kexts are not loading in sorted order. Mandatory kexts should load first.
- CPUFriend doesn't work alone. To inject the vectors, you require CPUFriendDataProvider.
- Your hardware shouldn't require AppleMCEReporterDisabler.kext.
- On Big Sur and above, AirPortBrcm4360_Injector.kext must be blocked from loading.
- CML has a native support and you shouldn't require injecting Fake CPU ID.
- Disable DisableIoMapper and switch to native VT-d.
Got it EFI
Trying to get WiFi working in Sonoma with no luck. What am I doing wrong? Screenshot 2026-03-25 at 7.39.00 PM.png
Trying to get WiFi working in Sonoma with no luck. What am I doing wrong?View attachment 10063
Your EFI is not as per the guide and problems are expected therefore. You have USB ports mapped and still using USBInjectAll+XhciPortLimit which defeats the purpose.
You shouldn't require AirportBrcmFixup.kext and the child ones. After you inject, you'll have to run OCLP to patch the volume.
I've had wifi fixed. Had it working that night. I posted that i got it but for some reason I don't see the post. I did remove the .kext you suggested. I knew I didn't need it and had intended doing so but hadn't done at that time.
How I go it working: I created a new folder " packages" in Library folder added autopkg-assets.pkg in the Sonoma install app. then reinstalled Sonoma, worked flawless.
Only issue I have yet resolved is display not getting signal after log in screen. I can disconnect cable and plug it back in and it works fine. I've tried -cdfon with no luck. I havn't given up though. lol
okakei
