Dell OptiPlex 5080 i7 10700
Your EFI is not as per the guide and the problems are expected.
Here are a few issues:
- Remove all the OEM DSDT and SSDTs as they are loaded by defaults unless blocked/dropped.
- Use the standard set of SSDTs for CML.
- Remove ResetLogoStatus
- Your hardware has Intel IGPU. Why are you renaming the model to be Radeon Pro 5700XT?
-The framebuffer patching isn't enabled as well.
- Kexts are not loading in sorted order. Mandatory kexts should load first.
- CPUFriend doesn't work alone. To inject the vectors, you require CPUFriendDataProvider.
- Your hardware shouldn't require AppleMCEReporterDisabler.kext.
- On Big Sur and above, AirPortBrcm4360_Injector.kext must be blocked from loading.
- CML has a native support and you shouldn't require injecting Fake CPU ID.
- Disable DisableIoMapper and switch to native VT-d.
Got it EFI
Trying to get WiFi working in Sonoma with no luck. What am I doing wrong? Screenshot 2026-03-25 at 7.39.00 PM.png
Trying to get WiFi working in Sonoma with no luck. What am I doing wrong?View attachment 10063
Your EFI is not as per the guide and problems are expected therefore. You have USB ports mapped and still using USBInjectAll+XhciPortLimit which defeats the purpose.
You shouldn't require AirportBrcmFixup.kext and the child ones. After you inject, you'll have to run OCLP to patch the volume.
kaikkmi
