GUIDE [HELP WANTED] Reboot after Apple logo with progress bar
Sudoceo
MSI B550 Tomahawk Max Wifi
Ryzen 7 5700x
Msi RX 6800 XT
Hi there! I have created EFI folder with help of OpCore-Simplify. And now I have a problem, after selecting OpenCore(dmg) option there is some boot output and then Apple logo with progress bar appears, after couple of seconds (1-3) my pc just restarts. MacOS version is 26 Tahoe My build:
Ryzen 7 5700X
MSI B550 tomahawk max wifi
RX 6800 XT
Kingston fury 2x16 3600 16cl
Kingstone KC3000 2TB
Some bios info:
I have secure boot turned OFF, SVM mode ON, Re-Size BAR Support ON, Above 4G memory/Crypto Currency Mining ON
Here is my EFI folder and screenshot
  • EFI.zip
    EFI.zip
Ryzen 7 5700X
RX 6800 XT
Some bios info:
Your EFI is not as per the guide and the problems are expected.
Here are a few issues:
- Remove ResetLogoStatus
- Remove FixupAppleEfiImages
- Set Re-Size BAR to Disabled/OFF and set the ResizeAppleGpuBars to -1.
- CtlnaAHCIPort.kext shouldn't be needed with your setup.
- You should remove CustomSMBIOSGuid and set the UpdateSMBIOS to Create.
- You should remove NootRX as 6800XT is supported OOTB.
- You should consider enabling verbose to show output to trace the issue.
Thanks for your help! I followed your instructions, and the behavior changed slightly, but the system still won't boot. I also attached an archive with a photo showing the last logs, after which the system reboots and hangs with a black screen. I waited about 8 minutes, but nothing changed.
What's the GPU brand?
usersebas12992
