[HELP WANTED] Reboot after Apple logo with progress bar
Sudoceo
15.x
Hi there! I have created EFI folder with help of OpCore-Simplify. And now I have a problem, after selecting OpenCore(dmg) option there is some boot output and then Apple logo with progress bar appears, after couple of seconds (1-3) my pc just restarts. MacOS version is 26 Tahoe My build:
Ryzen 7 5700X
MSI B550 tomahawk max wifi
RX 6800 XT
Kingston fury 2x16 3600 16cl
Kingstone KC3000 2TB
Some bios info:
I have secure boot turned OFF, SVM mode ON, Re-Size BAR Support ON, Above 4G memory/Crypto Currency Mining ON
Here is my EFI folder and screenshot
  • EFI.zip
    EFI.zip
Ryzen 7 5700X
RX 6800 XT
Some bios info:
Your EFI is not as per the guide and the problems are expected.
Here are a few issues:
- Remove ResetLogoStatus
- Remove FixupAppleEfiImages
- Set Re-Size BAR to Disabled/OFF and set the ResizeAppleGpuBars to -1.
- CtlnaAHCIPort.kext shouldn't be needed with your setup.
- You should remove CustomSMBIOSGuid and set the UpdateSMBIOS to Create.
- You should remove NootRX as 6800XT is supported OOTB.
- You should consider enabling verbose to show output to trace the issue.
Thanks for your help! I followed your instructions, and the behavior changed slightly, but the system still won't boot. I also attached an archive with a photo showing the last logs, after which the system reboots and hangs with a black screen. I waited about 8 minutes, but nothing changed.
What's the GPU brand?
Hi, sorry for delay. I have attached screenshots with almost all bios settings, if you still can't find anything specific, let me know.
Enable 4G Decoding and SR-IOV Support. Attach the verbose video.
OK, I've enabled these settings. Now, after starting computer continues to work, but there is no video signal. After about 10 minutes. nothing happens because of the waiting. Unfortunately I cannot attach video as mp4 not allowed.
Voltvol
