Black screen after Apple logo comes for a second while installing Hackintosh Sequoia
zerotwo_here
Asus ROG Strix G15 G513QM 2021 Electropunk Edition
AMD Ryzen 9 5900HX
Nvidia RTX 3060 Laptop GPU 6GB DDR6
Device Specifications:-
Laptop- ASUS Rog Strix G15 G513QM 2021 Electropunk edition
AMD Ryzen 9 5900HX 3.30Ghz
16GB DDR4 Ram
RTX 3060 Laptop GPU
Intel Bluetooth and Wifi card
i am trying to install hackintosh Sequoia for my laptop but the problem is i am getting a apple logo for some seconds then a complete black screen i want to fix this issue help me with it, i dont know much about EFI stuff but still help me with easy explanation
according to my observation if i use -wegnoegpu bootarg then i can atleast able to get apple logo but if i use different bootargs i get some PCI configuration something then screen goes black, help me install this hackintosh onto my laptop
I am sharing both of the issue in Video format and the EFI size is 52 MB which is too large for the server to upload so i am uploading a google drive link with a public accessEFI Download Link
16GB DDR4 Ram
RTX 3060 Laptop GPU
i tried ur guide but it doesnt work at all in my case so i use opencore simplify for efi building and then i use usbtool for get my utbmap and then i changed it thas it when i asked to chatgpt about it, it says its cuz of the display problem the hackintosh is running fine its all about the display problem which is not booting from AMD instead its running from Nvidia
Attach the EFI you prepared from the guide.
WYLDE983
