- Oct 13, 2025
- Gigabyte B650 Eagle (Bios F35)
- AMD Ryzen 5 7500F
- AMD Radeon RX 9060 XT
- 14.x
Hi guys!
Been trying to install MacOS Sonoma on my desktop for the first time and I run into some troubles.
First, I used pre-configured EFI folder at the beginning.Later I set it up correctly for MacPro6,1 and it had the apple support problem which was explained in guide that if this happens,
then I need to change to MacPro7,1. Which I did change to, but it sent me back to wake-failure problem.
Updated BIOS from F33 to F35 but to no improvements.
I studied similar cases with success or problems and copied their kexts etc. because I'm new to this stuff.
I'm pasting the error line below, my EFI folder and my PC specs.
I have flashed my MacOS on M.2 NVMe and I want to install it on the same SSD, I think this could be the problem, but I don't have spare USB for this now.
I would be much grateful for any help you guys can give me.
Much love brothers.
Specs:
Motherboard - Gigabyte B650 Eagle
CPU - AMD Ryzen 5 7500F
GPU - AMD Radeon RX 9060 XT
Audio - Realtek ALC897 (I think)
SSD - Patriot M.2 P300 128GB (SSD I'm trying to install MacOS on)
Wi-Fi/Bluetooth - MediaTek Wi-Fi 6E MT7922 160MHz
(IF THERE ARE ANY MISSPELLS OR SOMETHING
IT'S BECAUSE I TOOK PHOTO OF THE CODE AND COPIED FROM PHOTO)
Error lines after clicking install MacOS Sonoma in OpenCore:
#IEB.LD.LFIIN] O 1 <"(null string>"> <"1")
#CEB.B.SBSISZ1 723512#[EBIB:SHA] <5ff7a493bd9c631683fa0d2730af039b85952466>
#CEB.WL.PWLFNVI!] Err(@xE) <- RT.GV wake-failure 7C436110-AB2A-4BBB-A880-FE41995C9F82
#IEB.WL.DT|1] Err(0xE) <- EB.WL.PWLFNV
#LEB.WL.PWLFRTC INONE]
#CEB. WL.DT|!] Err(OxE) <- EB.WL.PILFRTC
#LEB.LD.LKCID] < System\Library\KernelCollections\BootKernelExtensions.kc.development*>
#LEB.LD.LF IN] O 1 {"Systen\\Library\\KernelCollect ions\\BootKernelExtensions.kc.development*> <"0*>
#LEB.LD.OFS|OPEN!] Err (OxE) ‹"System\\Library\\KernelCollect ions|\BootKernelExtensions.kc.development*>
#IEB.LD.LKCIR.2] ("System\Library\KernelCollecttons\BootKernelExtensions.kc">
#IEB.LD.LFIIN] D 1 <"Systen\\Library\\KernelCollections\\BootKernelExtensions.kc"> <*0">
#LEB|SB
#IEB|SB:SBGMFNS] J160ap.im4m
#IEBISB:MF] System)\Ltbrary|\KernelCol Lections]\BootKernelExtensions.kc.j160ap.Em4m
#IEB.LD.LF|INJ B 1 ("System)|Library\\KernelCol lections)\BootKernelExtensions.kc-j160ap.tm4m*> <"0*>
# LEB | SB:MKRN]
#IEB.LD.LKFSI-2] 0k(D)
#IEB.LD.LKCI-7] Dk(D)
#LEBIBST: REV1]
#LEBICSR:OUT] 0x00000040
#IEB.BST.FBSI+]
#LEB.BST.FBSIADSZI O
#LEB.BST.FBS|KSSZ] O
#LEBISB:SBGMFNS] J160ap.im4m
#LEB IRH
#LEBIRH:MF] <"usr|Istandalone1105.cmg.root_hash.j160ap. Lm4m*>
#IEB.LD.LF|IN] O 1 Kuspiistandalone(\0S.cmg.root_hash*> <*0*>
#IEB.LD.OFS|OPEN/] Err(OxE) <"usrhhstandalone\\05.dmg-root_hash*>
#LEB.RH.LRH|P!] Err(0xE) <- EB,LD,LF#IEB.BST.FBS|!] Err(0xE) <- EB,RH.LRH
#LEB|LOG
