Tahoe Apple ALC kext not working
skjaiswal
dell inspiron 15r
i5
2GB
15.x
Hi
I have upgraded to MacOs Tahoe from mac os sequoia after updating the kext and usb port mapping (guided by EliteMacx). Audio was working fine with apple ALC in Sequoia but not with Tahoe. So I have removed AppleALC kext from EFI and alcid-11 from boot arg and installed VoodooCompiler.tool and VoodooHDA.pkg from https://olarila.com/topic/42836-easy-audio-solution-on-hackintosh-on-macos-tahoe/.
After installation I add Audio Layout ID 99 (Number) in config.plist and rebooted and sounds are showing in setting but I can hear only music no vocals of any video with poor audio quality. Kindly help with proper mathod to fix it.
USB Wifi not working, I have installed Wireless-USB-Big-Sur-Adapter which was working in Sequoia but not detecting in Tahoe. kindly help which USB wifi adaptor to installed in Tahoe.
Thanks in advance.
i5 -10400 CML
UHD630
Hi
Thanks in advance.
i5 -10400 CML
UHD630
Tahoe has removal of the kexts so it must be patched. If you don't want to go this route, just use VoodooHDA.
delta385852
