HP Pavilion G6 1250ej
ShonP40
Gigabyte GA-Z270-HD3P
Intel Core i7-7700K
AMD Radeon RX 6600 XT
15.x
Hi, I am trying to install MacOS High Sierra on my HP Pavilion G6 1250ej laptop.
I used UniBeast to create a legacy installation on my USB flash drive (because this laptop doesn't support UEFI) and added the necessary kexts and patches from this GitHub repository.
I booted the installer on the laptop, saw the Apple logo and after a couple of minutes it switched to a grey screen with the mouse curser (I am able to move it). The installer it self and the status bar are not showing up at all.
Is there a fix to it?
No specs provided. Follow the guide here:
1. I used a USB 3.0 32GB flash drive.
2. Here are the specs of the laptop:
Intel ® Core ™ i3-2330M
6 GB RAM
AMD Radeon HD 6470M and Intel HD Graphics 3000 GPU's.
There are no USB 3.0 ports on this laptop.
6 GB RAM
Follow the guide i linked above.
Ok, I followed your guide and I am still getting to the same screen.
nvm, I removed the patches that I got from the GitHub repo and it booted up the installer!
I just noticed that only one of my 3 USB ports is working. Is there any fix to it?
nvm, I solved it by using the patches from the GitHub repository.
EWJ
