BCM920702 on MAC OS 13.7.5 Ventura Not working
zabardastibyabbas
MSI Mortar B760M
Core I5 12700
RTX 5700 XT
  1. iMac Pro
Hi, i am new here and too much noob. first of all thanks for all your youtube videos which help me a lot.
I installed mac os on my core i5 12700. and installed wifi Bluetooth card. wifi is working but bluetooth (BCM920702) is not working
it showing in system information under usb hub 2.0 but not working.
i put relevant kext files in kext folder and use open core confiscator but still not getting why its not working.
i am attaching the screenshots kindly help me
Screenshot 2025-05-28 at 7.43.03 PM.png Screenshot 2025-05-28 at 7.41.47 PM.png Screenshot 2025-05-28 at 7.41.07 PM.png
View attachment 9464View attachment 9463View attachment 9462
Why are you using USBInjectAll when you have mapped the ports?
thankyou sir for reply
a lot of things i have done what Chatgpt told me to do, maybe i mapped these ports but when i deleted USBInjectall from config.plist in results, no usb device was showing under system information > usb. So i added USBInjectall back in config.plist so they showed up again.
now i am tired of this. its being a week. i still unable to figure out what should i do to make my bluetooth work. please help and guide me. is there any way you can access my computer and do it by yourself? i'll be grateful to you
sir please reply me my all hopes are on you,
and kindly tell me that if i buy Fenvi T919 will it automatically install in my macos without any further steps??
Its you who needs to fix the issue and attach the files again to re-check.
No. It really depends on what macOS version you plan to use and as always, there are some prerequisite even when the particular hardware in the question has native support.
alvarg82
