GUIDE :🛠️ macOS Sequoia Installation Fails with Prohibited Sign on Hackintosh
Hurling7051
Gigabyte H410M S2 V3 (BIOS F10b - Jun 10, 2025)
Intel Core i3-10105
Intel HD Graphics 630
15.x
âť— Issue: Can't Start Installer – “StartImage failed - Aborted” + đźš« Prohibited Sign​
Hello Hackintoshers,
I'm currently trying to install macOS Sequoia on a system using OpenCore (likely 0.9.9 or newer), and I've run into a show-stopping issue that might need deeper insight from the community.
đź’» System Specs:​
ComponentDetails
MotherboardMSI H110M PRO-VH PLUS (MS-7A15)
ChipsetIntel H110 (Skylake PCH-H)
CPUIntel Core i3-7100 (Kaby Lake, LGA1151)
iGPUIntel HD Graphics 630 (Kaby Lake GT2)
RAM8GB DDR4 2400 MT/s
BootloaderOpenCore (latest)
BIOSAmerican Megatrends, v1.C0 (UEFI, 06/16/2018)
Super I/ONuvoton NCT6793D/NCT5563D
🧨 Problem Description:​
When I boot from the macOS Sequoia USB installer via OpenCore, it shows up fine in the boot picker. However, selecting the installer results in:
  • A black screen
  • A prohibited symbol (đźš«) showing up almost immediately
  • A message saying:
    makefile
    CopyEdit
    OC: StartImage failed - Aborted
This happens before the Apple logo or loading bar appears — so it's not reaching the macOS bootloader at all.
🕵️‍♂️ What I’ve Checked So Far:​
  • âś… OpenCore Picker works fine.
  • âś… USB drive is formatted correctly with Install macOS Sequoia created using gibMacOS + createinstallmedia.
  • âś… Reset NVRAM via OpenCore menu.
  • âś… Verified SecureBootModel is set to Default or j137.
  • ⚠️Suspect the issue may be:
    • A mismatch in MinKernel/MaxKernel settings for some kexts.
    • iGPU framebuffer misconfiguration for HD 630.
    • Missing/incorrect Vault, SecureBoot, or SIP settings.
    • Incomplete or unsigned installer image (based on the "StartImage failed" hint).
📸 Reference Images:​
I’ve attached the boot screen errors as images in case visual inspection helps:
  • Prohibited sign appears right after selecting the Sequoia installer.
  • "StartImage failed - Aborted" shows briefly.
🙏 Looking for:​
Anyone who’s:
  • Installed Sequoia on Kaby Lake successfully.
  • Dealt with the StartImage failed error during boot.
  • A working SSDT-SWAC-DISABLE.aml or advice on generating it
  • Has a working config.plist or advice for frame buffer patching on HD 630.
  • added an EFI file and error video.
Thanks in advance for your time! Hoping the community can help me crack this issue and finally get Sequoia running on this build.
— Hackintosh Helper
đź’» System Specs:​
ComponentDetails
  • A black screen
  • A message saying:
    makefile
    CopyEdit
🙏 Looking for:​
Anyone who’s:
— Hackintosh Helper
Your EFI is not as per the guide. Here are a few issues:
- Disable EnableWriteUnprotector and Enable RebuildAppleMemoryMap and then check. Also, you shouldn't require FixupAppleEfiImages.
- Kext loading order is not correct. Important kexts should load first. (Lilu, VSMC, WEG, AppleALC).
- You shouldn't require to spoof the CPUID. Remove the Cpuid1Data and Cpuid1Mask.
- Set UpdateSMBIOSMode to Create.
ploukop
