Could anyone advise how to enable hardware acceleration on my AMD graphics card?
1007398368
X570
5600倍
专业二人组(斐济)
15.x
  1. Mac Pro
My GPU is Pro Duo (Fiji), but it doesn't support H.264 and HEVC hardware acceleration, including VDA decoding. My CPU is 5600x—could anyone tell me what I should do?
I would greatly appreciate it if any experts here could help me out! Thank you so much again with all my sincerity!
This is my EFI folder. Thanks again!
No EFI attached. Add -radcodec in boot args and then check.
Sorry, due to network issues, I wasn't able to upload it before. I’m re-uploading it now—could you please take a look? I’ve tried adding the -radcodec boot argument, but it didn’t work.
未连接 EFI。在 boot args 中添加 -radcodec,然后检查。
Dear Official Administrator,
Thank you very much for taking the time to respond to me. My graphics card is the PRO DUO (Fiji), an AMD dual-GPU single-card model. I hope you can spare some time to review my EFI configuration and provide me with some optimization suggestions. Thank you very much, and I wish you a pleasant life!
-radcodec is missing from the boot arg.
Thank you for the wishes. Wishing you the same. Try to add the boot arg and then check.
alvarg82
