Need Help for Intel arrow lake hackintosh 265K MSI Z890 S wifi
chaitanya
MICRO-STAR PRO Z890-S WIFI (MS-7E54)
Intel(R) Core(TM) Ultra 7 265K
RX6900XT
15.x
  2. Windows Phone
#[EB.LD.LFIIN] O 1 <"《null string>"><"1">
#[EB.B.SBSISZ] 723512
#[EBIB:SHA] <369a5cd084b8fb18a54e08971fc54ce22e336542>
#[EB.WL.PWLFNVI!] Err(OxE)<- RT.GV wake-fai lure 7C436118-RB2A-4BBB-R888-FE41995C9F82
#[EB.WL.DTI!] Err(OxE)《- EB.WL.PWLFNV
#[EB.WL.PWLFRTC |NONE]
#[EB.WL.DTI!] Err(OxE)《- EB.ML.PWLFRTC
wtEB:L6:Lkcibic*system\Library\KernelCoLlections\BootKernelExtensions.kc.derelopment"?
#[EB.LD.OFS |OPEN!J Err(OxE) <"System\\Library\\KernelCoLlections\\BootKernelExtensions.kc.development">
#[EB.LD.LKCIR.2] <"Systen\Library\KernelCol lections\BootKernelExtensions.kc">
[EB.LD.LKFS|-7] Ok(0)
#[EB.LD.LKC|-?] Ok(0)
#CEBIBST:REV1]
#CEBICSR:IN] Ox00000A43#[EBICSR:OUT] Ox00000R43#[EB.BST.FBS|+]
#[EB.BST.FBS IRDSZI 0
#CEB.BST.FBSIKSSZJ 0
#LEBISB:SBGMFNS1 x86legacyap.Lm4m
#[EBIRH:PF] usr\standalone\OS.dmg.root_hash
#LEB IRH:MF] <"usr\\standalone\\0S.dmg.root_hash.x86legacyap.im4m">#[EB.LD.LFIIN] 0 1 <"usr\\standalone\\0S.dng.root_hash"><*0">#[EB.LD.OFSIOPENI] Err(θxE) 《"usr\\standalone\ \0S.dmg.root_hash">#[EB.RH.LRHIPI] Err(OxE)<- EB.LD.LF
#[EB.BST.FBSI!] Err(OxE)<- EB.RH.LRH
#[EBILOG:DT] 2025-03-24T10:09:36
CEBILOG:EXITBS:STRRT] 2025-03-24T10:09:36
I was stuck in exactly the same spot for three days. The deactivation for V-TD is hidden in my Asrock Phantom Z890. You have to disable all relevant CPU virtualizations. Most importantly, Resizer must be disabled, as well as the iGPU. That's how it worked for me.
#CEBIBST:REV1]
Attach your BIOS Settings.
Yes, that's right!
Bildschirmfoto 2025-04-21 um 02.56.56.png Bildschirmfoto 2025-04-21 um 02.58.37.png
Oh my goodness, I did it.
Many online videos only tell half-truths, or just enough to make it work.
Fine-tuning is very laborious.
There are three options that need to be adjusted with the BIOS and OpenCore settings:
CPU Speed:
  • Kernel quirks AppleXpcmForceBoost must be enabled.
  • In conjunction with CPUFriendDataProvider.kext, this must be created separately, and the ctrsmt=full option in the NVRAM boot targets will display the Turbo mode of Ultra CPUs!
Kernel:
  • Disable IoMapper is linked to the BIOS VT-D and should remain enabled in OpenCore...
It's running and damn fast.
BUT, if it weren't for that damn word...
After hibernation and waking, everything worked perfectly. Now when I shut down the PC, it restarts after 2 seconds. I had this problem with an Intel NUK10 minicomputer. One user fixed it by conjuring a full SSDT, and it worked, including the TB. I've been experimenting with it for so long that I just don't know what to do anymore. The board and CPU are simply incredible.
But...
If anyone can help or has an idea, please feel free to write :)
  • Love
View attachment 9285View attachment 9286
Meine Güte, ich hab's geschafft.
Es gibt drei Optionen, die mit den BIOS- und OpenCore-Einstellungen abgestimmt werden müssen:
CPU-Geschwindigkeit:
Kernel Quirks AppleXpcmForceBoost muss aktiviert sein.
In Verbindung mit CPUFriendDataProvider.kext, das separat erstellt werden muss, und der Option ctrsmt=full in den NVRAM-Boot-Targets wird der Turbo-Modus von Ultra-CPUs angezeigt!
Kernel: Disable IoMapper ist mit dem BIOS VT-D verknüpft und sollte in OpenCore aktiviert bleiben...
Es läuft und ist verdammt schnell.
ABER, wenn da nicht dieses verdammte Wort wäre …
Nach dem Ruhezustand und dem Aufwachen funktionierte alles einwandfrei. Wenn ich den PC jetzt herunterfahre, startet er nach 2 Sekunden neu. Ich hatte dieses Problem mit einem Intel NUK10 Minicomputer. Ein Benutzer hat es behoben, indem er eine komplette SSDT heraufbeschworen hat, und es funktionierte, inklusive der TB. Jetzt habe ich so lange damit experimentiert, dass ich einfach nicht mehr weiter weiß. Das Board und die CPU sind einfach unglaublich.
Aber …
Have got no hands on it yet. Check XHC controllers as they often create problems when shutting down. Logs might be useful.
Reactions: karatasios
I used the debug version and also included a few logs from OC and the Hackintool. Thanks for your efforts.
jonsv2
