How to Enable ThunderBolt 2, Thunderbolt 3 and Thunderbolt 4 on maOS [Clover/OpenCore]
An EliteMacx86 Exclusive Guide - This guide covers implementation of Thunderbolt 2, Thunderbolt 3 and Thunderbolt 4 on macOS using Clover and OpenCore.
This guide covers the implementation of Thunderbolt 2, Thunderbolt 3 and Thunderbolt 4. Thunderbolt isn't a necessary thing but for some users, a working Thunderbolt function is required. Thunderbolt can be utilised for several things such as working with Audio interfaces, Display, File Transfer, connecting external GPU, and to connect any other Thunderbolt compatible devices such as Thunderbolt equipped Hard Drive or SSD.
When talking about Thunderbolt, Thunderbolt has the fastest speed as compared to the USB Type A, USB 3.1 and USB Type-C.
On Windows hardware, the working of Thunderbolt is different as compared to a real Macintosh.
For more information on Thunderbolt Hotplug, refer to the guide linked below.
Implementing ThunderBolt on macOS is quite easy and has very few requirements.
Supported VendorsIntel (Onboard), GIGABYTE GC-Titan Ridge, GIGABYTE Alpine Ridge
Thunderbolt compatibilityCompatible Thunderbolt Chip
KextsOriginal Thunderbolt Kexts S/L/E
Enabling Thunderbolt for any of the above vendors can be quite complex process and time consuming. If done correctly, you can have a working Thunderbolt with the required speed and performance.
Before you start
Note
  • Remove all the work done for the Thunderbolt implementation.
STEP 1: Installing Thunderbolt Card
Once you have your Thunderbolt Card, you're ready to install the Thunderbolt Card. To install the Thunderbolt Card, follow the steps outlined below.
1. Shut Down your System.
2. Open your PC case.
3. Install the Thunderbolt Card.
4. Connect the Power Cable.
5. Connect the USB cable to the USB 2.0 header available on the motherboard.
6. Connect the Thunderbolt Cable to the THB_C header available on your motherboard.
  • On a few motherboards, you may not have the TB Settings under BIOS. In such a case, you can simply skip the BIOS settings for Thunderbolt.
  • On a few Motherboards, you may not find the THB_C header. A workaround is to short or jump the PIN 3 and PIN 5 as described in this guide.
Following are the recommend physical slot locations for installing Thunderbolt Card.
Chipset SeriesRecommended SlotNotes
H55
  • PCH PCIe x4 slot only
P55
H57
Q57
H61
B65
Q65
P67
H67
Q67
Z68
B75
Q75
Z75
H77
Q77
Z77
H81
B85
Q85
Q87
H87
Z87
Z97
H97
X58
X79
X99
X299
  • PCH PCIe x8_2 slot only
  • If PCH PCIe x4 slot is not available, use PCH PCIe x8_2 slot.
C422
C621
C622
C624
C625
C626
C627
C628
H110
B150
Q150
H170
Q170
Z170
B250
Q250
H270
Q270
Z270
Z370
H310
B360
B365
H370
Q370
Z390
H410
B460
H470
Q470
Z490
W480
H510
B560
H570
Z590
X570
B550
TRX40
NOTE:
  • Installing the Thunderbolt in any other PCIe slot than PCIe x4 will require a flashed card with custom firmware for macOS.
STEP 2: BIOS Settings for Thunderbolt
With Thunderbolt, the BIOS settings are really important. Changing the BIOS settings to a bad one, the Thunderbolt card might stop working. The adjustment of Thunderbolt settings in the BIOS will help the card to utilise the Card and setup a connection between hardware and the macOS.
To access your UEFI, press and hold Delete key on your Keyboard. The key maybe different in your case. Refer to your Motherboard Guide/Manual.
The BIOS settings has been already explained in the main BIOS/UEFI thread. For more information on BIOS/UEFI settings, refer to the guide linked below. This thread only includes settings for Thunderbolt.
Built-in and AIC Thunderbolt
SettingsValueNotes
Discrete Thunderbolt(TM) SupportEnabledDefines Thunderbolt Support
TBT Vt-d base securityDisabled
Thunderbolt Boot SupportEnabled
Boot Once
Defines Thunderbolt Boot support. If Enabled option does not exist, use Boot Once option.
GPIO Force PwrEnabledForces Power to Thunderbolt
Skip PCI OptionRomEnabled
Wake from Thunderbolt(TM) DevicesEnabledAllows to wake from Thunderbolt Devices
Security LevelSL0-No SecurityDefines Thunderbolt Security Level
DTBT Controller 0Enabled
TBT Host RouterTwo port
Extra Bus ReservedDefaultThe default value after you reset the BIOS
Reserved MemoryDefaultThe default value after you reset the BIOS
Reserved PMemoryDefaultThe default value after you reset the BIOS
Reserved I/ODefaultThe default value after you reset the BIOS
SettingsValueNotes
PCIE Tunneling Over USB4DisabledOnly applicable for 600 series motherboard.
DTBT Go2Sx CommandEnabled
Windows 10 Thunderbolt supportEnable + RTD3Defines Thunderbolt support for Windows 10
Memory AlignmentDefaultThe default value after you reset the BIOS
PMemory AlignmentDefaultThe default value after you reset the BIOS
SettingsValueNotes
Thunderbolt USB SupportEnabled
SettingsValueNotes
Current Security LevelNo SecurityDefines Thunderbolt Security Level
Native OS Security for TBTEnabled
Thunderbolt USB SupportEnabledEnables Thunderbolt USB Support
Titan Ridge Workaround for OSUPEnabled
Tbt Dynamic AC/DC L1Enabled
Wait time in ms after applying Force PwrDefaultThe default value after you reset the BIOS
GPIO filterEnabled
Laptops
ASUS/Clevo
SettingsValueNotes
Intel Thunderbolt TechnologyEnabledDefines Thunderbolt Function
Security Level
  • Unique ID
  • Normal Mode w/o NHI
Unique ID
  • Found on newer Laptops.
Normal Mode w/o NHI
  • Found on some old Laptops such as Haswell. Use this option instead of Debug Mode
Thunderbolt Boot SupportEnabledDefines Thunderbolt Boot support.
SettingsValueNotes
TBT Vt-d Base SecurityDisabled
Thunderbolt Boot SupportDisabled
Security Level
  • No Security
  • SL0-No Security
  • Legacy Mode
  • Unique ID
  • One time saved Key
  • DP++ only
  • Debug Mode
  • Defines Security Level
No Security
  • For most of the motherboard and Laptops, this option is preferred.
SL0-No Security
  • For some motherboards, you may not have option of "No Security" in such case, use this option which is similar to "No Security".
Legacy Mode
Unique ID
  • This option is only applicable to Laptops.
One time saved Key
DP++ only
Normal Mode w/o NHI
  • Found on some old Laptops such as Haswell. Use this option instead of Debug Mode.
Debug Mode
  • Found on some old Laptops such as Haswell. Use "Normal Mode w/o NHI" option instead of Debug Mode.
Thunderbolt Usb SupportDisabled
TBT Host RouterDefaultThe default value after you reset the BIOS
TBT Root port Selector
  • Auto Detect
  • Thunderbolt USB
Auto Detect
  • For some High End Builds, you may need to select the port. It's recommended to set it to Auto Detect.
Thunderbolt USB
  • For some High End Builds, you may need to select the port. If Thunderbolt USB option is available, it's advised to set this option only.
Thunderbolt(TM) PCI Cache-line sizeDefaultThe default value after you reset the BIOS
Reserve memory per phy slotDefaultThe default value after you reset the BIOS
Reserve P memory per phy slotDefaultThe default value after you reset the BIOS
Reserve IO per phy slotDefaultThe default value after you reset the BIOS
Delay before SX ExitDefaultThe default value after you reset the BIOS
GPIO FilterEnabled
Enable CLK REQDisabled
Enable ASPMDisabled
Enable LTRDisabled
Alpine Ridge XHCi WAEnabled
AR XHCI Host Pre-WakeEnabled
AR XHCI Host Active LTRDefaultThe default value after you reset the BIOS
AR XHCI Host High LTRDefaultThe default value after you reset the BIOS
AR XHCI Host Medium LTRDefaultThe default value after you reset the BIOS
AR XHCI Host Low LTRDefaultThe default value after you reset the BIOS
  • If your Motherboard or the Laptop doesn't have the options mentioned above, you can simply skip those settings.
  • For Thunderbolt cards or chips with flashed firmware, disable "Thunderbolt USB Support" and if there is no such option, disable "Thunderbolt Boot Support."
STEP 3: Connecting Thunderbolt Device
Now the Thunderbolt is ready to use. Here's how to connect your TB Device.
1. Turn on your TB Device.
2. Connect it to your PC.
3. Turn on your PC.
And you can enjoy using your Thunderbolt Device.
Greetings and thanks for allowing me to be in this group.
I am new and have very little experience with installing macOS on a non-original computer.
After many, countless attempts, I have finally managed to install Catalina 10.15.4 with OpenCore.
I need to work WIFI, Bluetooth and Thunderbolt 3.
For WIFI and Bluetooth I have already found out that at the moment it is not possible for my hardware.
I thought the same for Thunderbolt, which is very important to me. I need to connect my sound card to this one.
Until I found this page. Now I have new hope of getting it.
From what I can read in your post this seems to be very easy, but I don't have much knowledge and I'm not sure about this.
First of all, you say that a Compatible Thunderbolt Chipset is necessary. My motherboard seems to have a Thunderbolt (TM) Controller -15E8 as indicated by Windows 10 Device Manager.
Second, you refer to Vanilla Thunderbolt kexts in / S / L / E. I don't know where I can get this kext and what should I do with it?
And finally, not all of the BIOS settings that it lists, are available on my motherboard.
I'm a little confused. Could you shed a little light on my confusion to help me resolve this?
I would greatly appreciate your help.
As per your profile, looks like you're having an AMD Build. As per the rules, we do NOT support AMD yet.
What ThunderBolt Card you're using?
Original from Motherboard. Windows 10 Device Manager prompts "Thunderbolt (TM) Controller - 15E8"
Can you provide a screenshot from DPCI Manager or Device Manager>Device ID.
I'm not quite sure what you're asking me. Could it be this window?
15e8 is JHL7540 Thunderbolt 3 NHI [Titan Ridge 2C 2018]
Try the guide and report if it works.
Ok I will try !!! But I need information about this. Especially for "Vanilla Thunderbolt..."
  • Compatible Thunderbolt Chipset
  • Vanilla Thunderbolt kexts in /S/L/E
Where can I download this? and what do i have to do with that kext? How do I include it in my system?
I have only managed, after much effort, to run a boot Pendrive !!!
My knowledge is very limited !!!
I deeply appreciate the help you are giving me !!!
Many thanks!!!
Many thanks!!!
Vanilla kexts in S/L/E means the original Apple TB kexts.
Ok, but I do a search in Spotlight and nothing similar appears on my computer. Also I would not know what to do with that or those kexts.
I include a screenshot with the information from the system.
ANARKRUTOI
