Need help to avoid Hard Restart of laptop
TrevorPhilips
HP
AMD Ryzen 5 5600H with Radeon Graphics
Radeon RX 5500M
15.x
I am trying to make EFI to make macOS work on my laptop, but every time I have to Force Shutdown when something goes wrong. Is there any software or trick to check errors and stuff without booting EFI bare-metal on laptop again and again?
What do you mean by "when something goes wrong"? Is restart not working?
When I try to install macOS in any new device then it is going to be the trial and error method , so everytime i have restart whole system to check whether changes worked or not , like installing new kext ,, so is there any method or software to trick to check where i can see what will happen when i boot the EFI ,like virtual environment or anything else in Windows...
and one more thing -->
When I try to open System Settings or any others apps i get this type of error majority of time , it fixes for one when I restart mac but , It appears again after sometime ,, how to fix it ?
No, nothing like that. You'll have to restart for the changes to take effect.
Looks like there is some problem with the EFI.
ploukop
