macos boot option not showing in opencore menu
preetshah
x513ia
ryzen 5 4500u
vega 6
hi im trying to install macOS Sonoma on my amd ryzen 5 4500u laptop
i have been able to install macos from macos recovery installer using usb
however after installing opencore does not show macos boot option
the mac.dmg in the image is the usb installer
upon booting macos installer from image it just reboots back into opencore menu i have attempted this multiple times
EFI
here is my efi
canot get pr files as macos wont boot
EFI
here is my efi
You must boot via macOS Installer entry for a couple of times. Once the macOS is installed, you can finally boot via Macintosh HD or (whatever your disk name is).
nnaa
