[SOLVED] Intel UHD Graphics 620 (Whiskye Lake) Graphics Glitch Issue
I don't know how to make a log of verbose
The error is very common. The crash is due to less pre-alloc DVMT size. Less than 32MB.
Try the following.
  • Use the original Device ID and ig-platform-id and prepare a PR file. Make sure to check the Graphics.
  • Use the modified Device ID and ig-platform-id and uncomment all the "#" from the patch.
Attach new PR files.
Reactions: Silvered
Try the following.
I have uncomment all the "#" from the patch but It crash. Seem the same error
Reactions: Silvered
I can't boot, only balck screen. Maybe i can boot with -igfxvesa and make a debug, it's okay?
Try to wait for 3mins and then check if you can get the display. If already booted, restart and then check.
Reactions: Silvered
gopon_user
