SOLVED Fenvi FV T-919 Bluetooth only working
OMG it's finally working, I thought I spent 30 euros for nothing, thanks a lot :))
Glad to hear!
I have just a last question, can I update to Sonoma with this setup or no?
Cat Confuse GIF by Rizal Althur
I thought you were running Sonoma :unsure:. At least, that's what your profile says!
Yes, I am running Sonoma but I used it because I wanted a stable hackintosh. I want to upgrade to sequoia but I think your opinion can help me. Is it useful or not?
Yes, I am running Sonoma but I used it because I wanted a stable mackintosh. I want to upgrade to sequoia but I think your opinion can help me. Is it useful or not?
Then, not sure why you said if you can upgrade to Sonoma when you're already running Sonoma. Probably, you meant to say Sequoia. If that's the case, yeah, you can upgrade. Follow the guide and you should be able to upgrade successfully. Just ensure to backup your important files.
As the original issue is resolved, this thread will be closed. Please create a new thread if you have additional questions/issues.
alvarg82
