SOLVED Fenvi FV T-919 Bluetooth only working
Here's my EFI folder. Hope it can help you.
Sadly, the EFI is not as per the guide.
Why are you having bunch of Ethernet kexts? As per the hardware indicated in your profile, has Intel Etherent. No idea why are you trying to load AppleIGC, Atheros, LucyRTL8125 and RealtekRTL8111.
MacPro7,1 isn't the right choice for your hardware. iMac should be preferred.
Your USB Ports are also not configured well. See below:
Regarding the WiFi, you're missing the required kexts. See STEP #3 (Apple AirPort and Fenvi Cards). Read the guide very carefully and follow step by step guide.
So, what SMBIOS exactly I need to choose?
and what network kext do I need to delete?
and I'll try again to make fenvi card work.
Uhh, is it normal that after I mapped my usb ports, I switched the smbios to iMac20,1 and no usb ports are working
Yes, that's normal. You can change the SMBIOS in the USBMap plist.
How can I do that? I used hackintool and I only have USBports.kext
Open the .plist of the USBports.kext and replace the iMacPro1,1 with iMac20,1. There should be probably two instance and you need to change both of them.
Thanks, USB is working but in your tutorial the file IOSkywalkFamily-v1.1.0.zip is on error 404 on github, can you give me the file please.
Glad to hear. Thank you for notifying. The link has been updated now!
OMG it's finally working, I thought I spent 30 euros for nothing, thanks a lot :)). I have just a last question, can I update to Sonoma with this setup or no? 1738180480479.png
alvarg82
