Sadly, the EFI is not as per the guide.Here's my EFI folder. Hope it can help you.
Why are you having bunch of Ethernet kexts? As per the hardware indicated in your profile, has Intel Etherent. No idea why are you trying to load AppleIGC, Atheros, LucyRTL8125 and RealtekRTL8111.
MacPro7,1 isn't the right choice for your hardware. iMac should be preferred.
Your USB Ports are also not configured well. See below:
How to Map your USB Ports on macOS
An EliteMacx86 Exclusive Guide - This guide covers the mapping of USB Ports on macOS. By following this guide, you'll be able to map your USB ports and can also achieve a proper speed for your USB ports.
I. Overview
Often, the USB ports are not well recognized or have certain issues. To fix that, USBInjectAll.kext from Rehabman was serving the purpose along with the USB port limit patch. Later on, for more performance and to avoid conflicts, and issues, a custom SSDT-UIAC was introduced. Later on, when Hackintool was...
I. Overview
- EliteMacx86
- amd usb map hackintool hackintosh intel usb map macos map port limit patch ssdt-ecusbx ssdt-uiac usb usb fix usb map usb map guide usb mapping usb ports usbinjectall usbtoolbox windows xhci xhciunsupported
- Forum: USB and Power
Regarding the WiFi, you're missing the required kexts. See STEP #3 (Apple AirPort and Fenvi Cards). Read the guide very carefully and follow step by step guide.
