Can my pc dualboot macOs sequoia and pre installed windows 11? (please answer ASAP)
itayav211
Gigabyte Technology Co., Ltd. B560M AORUS ELITE(U3E1)
Intel core i5 11600 @ 2.80GHz Rocket Lake 14nm Technology
Nvidia GeForce GTX 1650 (Gigabyte)
IMG_5600.jpeg IMG_5601.jpeg IMG_5603.jpeg IMG_5606.jpeg IMG_5607.jpeg Hi i saw your tutorial on youtube how to download macos sequnia and i have wondered if my pc meets the requirements? I want to dual boot pre installed windows 11 and macOS sequnia latest version or early version if it doesnt fully meets requirements. I have also been scrolling and scrolling for days and i couldnt understand what are the macos sequnia requirements if its gpu,cpu,motherboard ram audio ethernet etc. i would like you to tell me the hardware requirements and now i will show you my specs that are above and below here.
I cant detail much info about the Ethernet cuz of address and stuff but its called Realtk gaming 2.5GbE family controller, it is very very fast with link speed and internet speed both download and upload speed.
For the installation i already backed up my whole os and files etc with system image backup with my external drive, i also saved the bios with flash drive and i prepared emergency windows repair flash drive in worst scenarios, still if i need to save anything keep updating me.
For the macos can you tell me what is the max macOs my pc can run, additionally if my pc specs are not enough For macOs sequnia can you tell me what i should change but keep in mind my budget is very low meaning if i change something i need it to be nearly same budget and almost same performance(more or less doesnt matter just if its really near) and is giving full support for macOs sequnia.
Thank you very much for your time and sorry for writing you so much :<
View attachment 8925View attachment 8926View attachment 8927View attachment 8928View attachment 8929Hi i saw your tutorial on youtube how to download macos sequnia and i have wondered if my pc meets the requirements? I want to dual boot pre installed windows 11 and macOS sequnia latest version or early version if it doesnt fully meets requirements. I have also been scrolling and scrolling for days and i couldnt understand what are the macos sequnia requirements if its gpu,cpu,motherboard ram audio ethernet etc. i would like you to tell me the hardware requirements and now i will show you my specs that are above and below here.
View attachment 8922View attachment 8923
The CPU is supported, can be spoofed but the GPU isn't supported. The sad news is the IGPU is also isn't supported. So, you'll require a compatible GPU for the Graphics acceleration.
Reactions: itayav211
So every spec is supported to run MacOs sequnia(macos 15), i need to spoof my cpu to comet lake(idk how but i will find out) but unfortunately my gpu isn’t supported aswell igpu so i need to find compatible GPU to successfully run macOS sequnia? If thats so then i will go buy from the store or used gpu but i have a question.
Apparently my brother have nvidia geforce gtx 1050 ti and he agrees to switch with me the gpu’s and idk if that gpu fully supports macos 15 and can handle the igpu, additionally recently i told my dad i need new gpu because my gtx is almost crashing every single game i play so we plan to buy new one anyways and i would appreciate it so much if you can give me list for recommendations of gpus, and what brand is better for support for example i saw that the best recommendation for gpus is the AMD so if you can give me list for amd gpus that can handle the igpu and GPU compatibility i would appreciate it so much (from budget friendly to expensive) or if nvidia is the best for handling macos then the same.
Or every brand that in your view is the best for handling the macos and igpu
Thank you so much i owe you big appreciation
That's right!
Either works!
NVIDIA GPUs are no longer supported. The max supported was 10 series (Pascal) and that too on High Sierra. Since Mojave, there is no WebDriver support and since Monterey, the support for Kepler based Cards were also completely removed. Although, you use the experimental patch, but its not recommended, especially when you have the option to buy a new/used one.
You can find the list in the compatibility thread. You can use the following models:
- RX580/590
- 6600XT
- 6800XT
- 6900XT
These are some common models which can be bought for cheap in used market. As there is 700 series cards out there, it would be also hard to find new, unless someone has old stock. The recommended brands are Sapphire, GIGABYTE, MSI, ASUS. Sapphire and GIGABYTE are most preferred ones. Avoid XFX and Power Color. Although, these may work fine, there is no guarantee. Also, for XTXH variant, you'll likely need to spoof the Device ID.
The IGPU is on the CPU. In your case, its not supported on macOS. So, it will NOT work under macOS. However, if you specifically disable it in macOS, you can utilize the IGPU on Windows and Linux.
That's right!
Either works!
- RX580/590
- 6600XT
- 6800XT
- 6900XT
Got it thank you so much i cant even describe how much im grateful☺️
That's right!
Either works!
- RX580/590
- 6600XT
- 6800XT
- 6900XT
Hi men, I discussed with my parents. I tried looking for RX 6600 or later vers Gpu’s since we cant find store one we decided to look for used ones and we find two of them.
1: Sapphire RX 6600 8gb for 280$
2: Asrock RX 6800 XT 16gb for 470$
Based on your opinion tell me which should i get for full native support.
I rewatched the efi and macos installer videos and your fourms and i started questioning my self things.
1: i still couldnt find how to spoof my cpu and how to disable igpu i would appreciate it if you can send me guide or tutorial on your yt or fourm(i prefer yt).
2: my C disk(ssd) is GPT partition.
And my D disk(hdd) is MBR partition, do i need to do something about it? (Im useing UEFI).
3: there is 3 bios configures one from the fourm, the second from efi video, the third is from installing macos with preinstalled windows 11 video. All of them different which should i change based on?
4. Even if i spoofed my cpu or disabled my igpu, the bios configuration should i configure it by the specs of the spoofed one? Or the regular one(with igpu even if i disabled or enabled it) or the regular one(without igpu disabled or enabled)
The same question goes for EFI configuration.
5. I didnt 100% understand the EFI configuration process. Do i choose the ACPI files based on spoofed cpu like comet lake or regular cpu rocket lake (time at 5:32), at acpi config app at the delete option. My target is comet lake right? So i shouldnt change anything? (Time 7:25), at the booter(same config app) and quirks option i need to disable since im spoofing to comet lake? Also the adjustment should be comet lake or rocket lake (time 7:49), at kernel option emulate since im trying to spoof to comet lake i should choose comet lake right or just leave it empty?(time 9:18), at kernal quirks option i didnt clearly understand what should i do should i fill universal quirks or alder/raptor lake or vendor specific or just leave it empty (time 9:26), in the uefi apfs option what is the minDate and minVersion for macOs Sequoia(macos 15) (time 11:55), in the uefi quirks option i need to adjust with universal quirks or vendor specific or leave empty? (Time 12:33), when i reach time 13:12 i should go to the video where installing macos sequoia with pre installed windows 11? Because after 13:12 i see its the macos sequoia installation process.
6. The macos sequoia installation with pre installed windows 11 video.
Even after the EFI process i did before, should i keep the opencore from before? Or install the new one from the discription. If new one can you tell me the process i need to do I appreciate it.
Since i said before that my C disk (ssd) is GPT
and my D disk (hdd) is MBR and you mentioned before that ssd are better and on the rufus app i need to choose MBR should i do something about my c disk? Let me know.
When entering bios to configure should i configure based on the one you wrote on the fourm or the one you showed from the video?
Well im out of questions once you answer all of that i would be ready to dualboot macos 15 with pre installed windows 11, again im so sorry for making you read allat i owe you big thanks man huge thanks and thank you sooo much :”)
You're welcome!
Yo man so uh me and my parents want to choose the gpu, and since we are going to a trip in 3 days i need to decide asap what graphics card should i choose from the reply i wrote you below and uh can you give me the answer for the installation process questions from the reply below. thank you so much
Feeling bad for making you read all that but i really owe you big appreciation❤
You're welcome!
Yo bro inreally need answers please, i gonna go to a vacation in day and half i need to decide please answer asap man and tysm for your efforts i appreciate it🙏🏻♥️
Both have native support but the price seems costly. It could be due to different region. xD
Personally, i won't prefer ASRock GPUs. Sapphire, GIGABYTE are quite robust. When it comes to picking a part, only two thing matters the most. What workload you have and the budget. If you don't have any editing workloads then you can easily opt for RX 6600 XT. The plain RX 6600 performs a bit less and you should always opt for the XT variant, its the same for NVIDIA "Ti" resembles more powerful.
The EFI creation is a bit complex process and varies from hardware to hardware. Once you have the hardware ready, you can do it correctly.
EmileDiaz
