RX6650: Only one Display Port is working
Phil83
Asus B460M
I9 10900F
Sapphire RX6650
  1. iMac Pro
Hi together.
I got a Sapphire RX6650 XT and tried to spoof to work. I found two general options. Both works, but...
- Inject the Kext "NootRX": https://chefkissinc.github.io/applehax/nootrx/
All Ports (Display & HDMI) are working, better score on some Benchmarks. But the Temp is 10°C higher in Idle-Mode than the second option
- building the aml-file (SSTD-BRG0.aml) and Device Properties www.youtube.com/watch?v=V5bfEG6TfbM Just one Display-Port is working. DRM Protected Content (netflix, amazon prime) does not play, but the temp is more "friendly" in Idle-Mode.
What i like to do is the second option with all ports are working. With an RX6600 it was possible.
Hi together.
You should inject a compatible Device ID and then test the ports.
igor333333
