Stuck on AppleACPICPU Processor ID
didinwahyudin
ASUS D340MC H310M
I3 - 9100F
Shapire Nitro RX 580 4GB
Hello, I'm trying to boot on macOS Sonoma installer with the following hardware:
MOBO : ASUS D340MC H310M
CPU : I3 - 9100F
GPU : Shapire Nitro RX 580 4GB
Ram : XPG 8x2 16GB 3200Mhz
SSD : NVME 25GB
BIOS Setting
Fastboot Disable
VT-D diaable
Serial Port Disable
Pararel Port Disable
CSM Disable
Secure Boot Disable
I followed the Dortania Intel Desktop Guide (https://dortania.github.io/OpenCore-Install-Guide/config.plist/coffee-lake.html) to the letter.
I've changed between virtualsmc and fakesmc but the results are still the same
EFI folder, config.plist and photo of where I'm stuck are attached.
sorry for bad english
Hello,
Turn on Above 4G decoding in bios and disable npci=0x2000/0x3000
This helped for me.
CPU : I3 - 9100F
SSD : NVME 25GB
BIOS Setting
Fastboot Disable
VT-D diaable
Serial Port Disable
CSM Disable
Secure Boot Disable
Disable EnableWriteUnprotector and use RebuildAppleMemoryMap.
Switch to VirtualSMC.
Save changes and reset NVRAM and then try to boot again.
look this EFI
oke sir i will try
adamnor206
