Asus Vivobook X512DA
moishiteru2
Ryzen 5 3500U
Vega 8 graphics
Hi all, i have a problem to get working Sequoia very well on this notebook.
i have tested sucessfully ventura with the EFI here: https://github.com/LukeDevsE/Asus-Vivobook-X512DA
but with the same EFI i get kernel panic on install sonoma or sequoia
it is possible to check the EFI folder please?
thank you
thank you
Did you update the Kernel patches?
no I don't update anything I don't know how to update that...
ok i wil try thank you
someone has modify for me to work on Sequoia here the efi in attached file here:
i have issue to boot see video here:
Hope you can help
fresh install with the efi 0555 from my post before has this kernel panic
Hope you can help
The site gives blank files. Please use Google Drive or some other storage to upload files.
EFI 0555.zip Here u go, attached his EFI for you.
You don't need to look up actually.
See what his EFI has. NootedRed+Whatevergreen + RealtekCardReader + SMCs + AMDCPUPowerManagement + Bluetooth Kexts.
ALL THIS BEFORE INSTALL? @moishiteru2
Check out EliteMacX86's guides on youtube or just remove whatever I said for now 😅 if I am right.
You do not need all this for now, wait for @EliteMacx86 's reply, he'll tell you what to remove, or if I am right, will assist you in making EFI from scratch. That's the best option.
The thing is that, before installing macOS, you need very limited kexts, just so that it can install. All accessories can be installed later.
ALSO, PLEASE REMOVE WHATEVERGREEN and Disable NootedRED for now. YOU NEVER USE WhateverGreen+NootedRed together!
ok i will remove theses kexts you said thank you
you said "The thing is that, before installing macOS, you need very limited kexts, just so that it can install. All accessories can be installed later."
with the efi from github i install sucessfully ventura without delete any kexts....
moraWooChang
