exgpu didn't work fine
Iman
X510UQR
Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz, 1800 Mhz, 4 Core(s), 8 Logical Processor(s)
Intel(R) UHD Graphics 620 and NVIDIA GeForce 940MX
  2. OpenCore (Legacy)
  1. MacBook
Hi admin....thank you to you for guiding the installation process before, right now I've succeeded running macOS Ventura 13.7 in my Asus vivobook s150UA using KBLR CPU and Intel UHD 620 IGPU. Although, the IGPU works fine, I've wanted to run my Nvidia 940mx gpux here. The problem when using the gpux is 1. display brightness and brightness keys aren't functional.
Is there any ideas how.
I've attached my efi with boot args = -wegnoegpu turned on.
P.S. I've had to delete airportitlwm.kext and intelbluetoothfirmware.kext to shrink the size to be able to upload un the forum.
I've also attached the system information as reference. Thank you :)
  • EFI.zip
    EFI.zip
Optimus configuration aren't supported on Macs and it will not work. IGPU will be the only functional Graphics!
Okay noted... One more question, Based in the EFI attached before, Is there any ideas to speedup the boot time.
And if I updated to sequioa, will it works fine?
What SSD have you installed?
sammrafi
