Will this Wifi USB work?
ready2000
MSI MAG MORTAR MAX WIFI B550M
RYZEN 5500GT
RTX 3050 INNO3D 8GB
15.x
Well, I have done a complete analysis of my Laptop with the following specs:
Intel 8250U Processor
NVIDIA MX 150
Intel 8265 Wifi card
Now, I know that everything will work on my laptop, except the NVIDIA MX 150.
So, about the NVIDIA MX150 card, will it work? I have seen some videos saying it works using whatevergreen, some say it doesn't.
@EliteMacx86 , can you tell if it would work? BY HOOK OR BY CROOK? I really need it to get working. (I can't get my RTX 3050 on my PC to work but I really need this MX150 on my laptop to work on macOS)
PLEASE HELP
It will NOT work as its Optimus. Optimus configurations are simply not supported on macOS.
PLEASE HELP
Nah, its not going to work. Just a friendly reminder, do not always tag the members. When you reply, the notifications will sent to them automatically.
If MX 150 wont work... So can by hook or crook and tons of patching my RTX 3050 work?
I really need one of my GPU to work pls.
" Just a friendly reminder, do not always tag the members. "
I don't know I guess my one screw is loose, coz I have the habit of @ing everywhere. Will try taking care from now on
I was going to buy a RX 6600XT, which is about ₹6000 costlier, and still has 2048 shader units. I know that it's performance is sometimes better than 3050 and sometimes lower,
But overall it had lower performance than 3050, and my 3050 has 2560 shader units lol.
And development apps need DLSS/Ray tracing that's far better on NVIDIA. I actually supported and loved AMD cards since my birth becoz I didnt like intel and NVIDIA, but these big tech companies dude they dont like AMD. WHY?! Only Apple does!
Its a NO go. Just NO.
Get any supported GPU, if you really need it!
The Wire Reaction GIF
  • Haha
Reactions: ready2000
6600XT should be fine. But if you need more performance, then get RX6800XT.
Its about the general availability, market move, people's perception and the cost factor.
Ahh nvm for the Graphics card, new question:
Will this Wifi USB work in macOS?? Please tell (Note: I edited name of this post lol 😉)
Sounds good!
BTW, the WiFi Card you have, is compatible with the third party kexts and you can have WiFi+BT function working ;)
Sounds good!
Yeah actually that is for my PC, it has mtk card thats why.
Also:
This is the Dortania guide. It doesn't mention RTX 3050 in not supported at all. It means some patching can be done becoz ik that it is very similar to one of the RX cards, ig it's 6600XT OC.
Pls use all ur knowledge and tell if there is a 0.1% chance to spoof and use it. It's so nice it isn't included in the NOT SUPPORTED AT ALL LIST. Maybe becoz this card is used since ages? Please I request u once again to search all ur Highly Esteemed knowledge to get it working. It will also make you a bigger master of hackintosh as u will do something probably no one has ever done! :)
Ah ok.
Isn't that obvious? Cause, since Mojave, there has been no Webdrivers. So, its quite clear that after the NVIDIA 1000 series, none of them are supported on Macs.
Also, just because it has similar benchmark scores as compared to 6600XT, it does not really mean that it can be patched. In fact, both the architecture has a lot of difference. It's like saying Intel HD610 (GT1) can be patched with Intel HD620 (GT2). When the fact is that GT1 based GPUs are simply not supported on macOS.
I know whether its or some other people, we want that most of the hardware be supported on macOS platform, but Apple is very picky but that's how it is!
No Way Do Not Want GIF
Forget spoofing or thinking about some other trick. It will simply not work!
The reason is we don't have any idea about the drivers coding. This is because, it was Apple and NVIDIA who published the drivers and as there were drivers for NVIDIA 1000 series cards, it has been possible to make it work on macOS versions later than High Sierra, over the period of time!
I hope now that explains you why it is NOT possible!
Thanks for the motivation. Your request denied successfully 😛
imadeocy
