UNable to get my PC Hackintoshed (Solved)
The BIOS settings are not correct.
Set Resizable BAR to Disabled.
Set SR-IOV Support to Enabled.
In addition, it might be needed to set the Graphics to APU only. Anyways, make the above changes and then try to boot. Ensure that you reset the NVRAM at least twice.
Well, I made the changes as u said but nothing happened. Resettes nvram too. Since the video was blurred I'll show you exactly what it shows.
Sometimes it gets stuck at AppleACPICPU: Process, and reboots there, or else as u can see, it continues and then ends up at kernel panic. @EliteMacx86
Attach a full verbose video to check.
@EliteMacx86 Please check the google drive link I sent before, and download that video and play it. You will be able to see nicely where it gets stuck and reboots. (gdrive playback supports 360p only sadly) [Check out just the first 20 seconds that's all, then it reboots. And then the same happens]
ALSO NOTE THAT I HAVE AN RTX 3050 AND NEED IT DISABLED COZ IT WONT WORK AS U KNOW, AND my iGPU has to work so I guess that's the problem, maybe we need to do something with NootedRed....
There is no Google Drive link in your previous post. Please double check.
The video quality is so much poor. Barely anything is readable.
Seems like an RTC issue. Add SSDT-RTC.aml and then check.
did u try to download it... meanwhile i will try adding that
Hey I did that nothing changed but i have something to show.. I guess this pic shows whats wrong...... @EliteMacx86
As per the verbose, the path in the SSDT-RTC.aml is different. You must change it to match yours. Should be probably PCI0.SBRG.
Then, while the system tried to boot, there was a KP. Make the changes and attach your EFI to check.
natsukiro
