- Sep 26, 2024
- MSI MAG MORTAR MAX WIFI B550M
- RYZEN 5500GT
- RTX 3050 INNO3D 8GB
- 15.x
Well, First let me show my specs:
Ryzen 5500GT APU (It's just Ryzen 5600G but a little higher turbo speed; no difference)
RTX 3050 8GB INNO3D, ofcourse it can't work so I have added -wegnoegpu
MSI MAG MORTAR MAX WIFI B550M Motherboard
Now, I am trying to install macOS Sequioa for my PC, but am getting error as shown in the SS1 photo.
My EFI folder with config is attached that gets me to the kernel Panic in SS1.
Now, I have tried the following quirks on and off and I'll tell you what happened.
1. AvoidRuntimeDefrag -> as soon as I turn it on, I get stuck at LOG EXIT BS as shown in SS2. Switching it to off Atleast gets past that donno why.
2. Devirtualise MMIO -> this does nothing
3. SetupVirtualMap -> does nothing
4. SyncRuntimePermissions -> switching on gets stuck at logexitbs, switching off gets to kernel panic
5. RebuildAppleMemoryMap -> switching off again gets me to logexitbs.
6. According to Dortania guide, i tried everything and that EnableWriteUnprotector on + 2 things off and vice versa but no luck.
@EliteMacx86 I have made EFI from scratch using your VIDEO as well as the Dortania guide. No luck.
I have added NootedRed as i need to use my iGPU.
I have tried with Sonoma, Sequioa, Ventura and Monterey, none of them boots. Please help.
I have changed my BIOS Settings and I dont think aanything is wrong there.
EVM M.2 NVMe (2280) 512GB Internal SSD
16GB RAMNow, I am trying to install macOS Sequioa for my PC, but am getting error as shown in the SS1 photo.
