UNable to get my PC Hackintoshed (Solved)
ready2000
MSI MAG MORTAR MAX WIFI B550M
RYZEN 5500GT
RTX 3050 INNO3D 8GB
15.x
Well, First let me show my specs:
Ryzen 5500GT APU (It's just Ryzen 5600G but a little higher turbo speed; no difference)
RTX 3050 8GB INNO3D, ofcourse it can't work so I have added -wegnoegpu
MSI MAG MORTAR MAX WIFI B550M Motherboard
EVM M.2 NVMe (2280) 512GB Internal SSD​
16GB RAM
Now, I am trying to install macOS Sequioa for my PC, but am getting error as shown in the SS1 photo.
My EFI folder with config is attached that gets me to the kernel Panic in SS1.
Now, I have tried the following quirks on and off and I'll tell you what happened.
1. AvoidRuntimeDefrag -> as soon as I turn it on, I get stuck at LOG EXIT BS as shown in SS2. Switching it to off Atleast gets past that donno why.
2. Devirtualise MMIO -> this does nothing
3. SetupVirtualMap -> does nothing
4. SyncRuntimePermissions -> switching on gets stuck at logexitbs, switching off gets to kernel panic
5. RebuildAppleMemoryMap -> switching off again gets me to logexitbs.
6. According to Dortania guide, i tried everything and that EnableWriteUnprotector on + 2 things off and vice versa but no luck. :(
@EliteMacx86 I have made EFI from scratch using your VIDEO as well as the Dortania guide. No luck.
I have added NootedRed as i need to use my iGPU.
I have tried with Sonoma, Sequioa, Ventura and Monterey, none of them boots. Please help.
I have changed my BIOS Settings and I dont think aanything is wrong there.
  • EFI.zip
    EFI.zip
16GB RAM
A couple of things to note here.
Enable the following set of Booter Quirks first:
- AvoidRuntimeDefrag
- EnableSafeModeSlide
- ProvideCustomSlide
- RebuildAppleMemoryMap
- SetupVirtualMap
- SyncRuntimePermissions
The rest will be disabled.
Please dont give me answers like check this video check that video, @EliteMacx86 I have made EFI from scratch using your VIDEO as well as the Dortania guide. No luck.
Why not, if the EFI you prepared is exactly not as per the guide? If its as per the guide, no one is going to point out that your EFI is not as per the guide. xD
The kexts loading order is not correct. The guide does not ask to use SMCAMDProcessor, AMDRyzenCPUPowerManagement. As mentioned in the guide, the goal is to get the OS installed first and then you can tune/tinker/play with it.
Secondly, why you have used OpenVariableRuntimeDxe.efi driver? That's not meant for your system. You see? The EFI is not as per the guide!
Re-check the guide and adjust the parameters for the rest and enable the Booter Quirk mentioned in this post. Once you have corrected the EFI, attach it to cross check.
Reactions: ready2000
I actually contacted olarila support and they told me to put that and OpenRuntime with loadearly as true donno why.
But that didnt make any difference. As you have said, I'll make all the changes and soon reply. Thanks elite u r the greatest ever. Olarila is mad! Sry for that line actually it was bit copy pasted so that line was left. I have removed that. Ofc i need u to tell me what changes are needed! I'll reply soon after the changes
Okay so here is the updated EFI. Surprisingly, now even after setting AvoidRuntimeDefrag to True it didnt get stuck at LOG EXITBS. But, even after doing whatever changes u said, it's the same thing as in SS1.jpg i attached previously. Still kernel panics..... I wont stop this time bro pls help 😭
- SetupVirtualMap
Okay so here is the updated EFI. Surprisingly, now even after setting AvoidRuntimeDefrag to True it didnt get stuck at LOG EXITBS. But, even after doing whatever changes u said, it's the same thing as in SS1.jpg i attached previously. Still kernel panics..... I wont stop this time bro pls help 😭 @EliteMacx86
The EFI looks fine, except for the USBMap and USBToolBox and the kexts are still not in order.
How you have created the Bootable USB?
I really think USBMap and USBToolbox are necessary coz without that the EFI wont load anything... coz my mobo has way too many ports ig.....
Please tell me what order should the kexts be in @EliteMacx86 ????
I have created the Bootable USB using rufus as in your video and the recovery image using macrecovery.py
I have Monterey as of now in my drive, but I am trying whatever u r saying with Ventura, Sonoma and Sequioa as well.
Ports can be mapped during the time of the post installation for the maximum accuracy.
Lilu.kext
VirtualSMC.kext
AppleALC.kext
NootedRed.kext
AppleMCEReporterDisabler.kext
RestrictEvents.kext
For the moment, disable NootedRed.kext as well.
You can actually try macOS Sonoma.
What are the BIOS Settings? Is that updated?
  • EFI3.zip
    EFI3.zip
Well, please check the video now. i have made the changes: NootedRed Disable, removing UTBMap and USBToolbox. https://drive.google.com/file/d/1otpkMcuRWC5vI6_ZMn2xlQBk6reUkEAu/view?usp=sharing
Attached EFI and bios Settings as u needed @EliteMacx86
Yes, BIOS is updated.
The BIOS settings are not correct.
Set Resizable BAR to Disabled.
Set SR-IOV Support to Enabled.
In addition, it might be needed to set the Graphics to APU only. Anyways, make the above changes and then try to boot. Ensure that you reset the NVRAM at least twice.
eroldemirer
