[AMD 4700u] Kernel Panic when booting installer
Just checked the first video. Your SSD is not compatible. Use a compatible SSD or install it on the same SSD but via external (using an enclosure).
I've installed a Sabrent 512GB (which I didn't see that is incompatible so I think is good?) and the disk erase now works...but the installer got stuck again at 50/60% like the Video 2 and then the screen goes off and the laptop reboots ç_ç
Sabrent NVMes also have problem.
Attach BIOS settings and the EFI you are using.
The EFI folder is the same of the first post but with only the NootedRed kext disabled in config.plist as change.
On the other hand, and unfortunately, my BIOS is a shame, just 2/3 options as you can see(I've also tried to disable SVM but nothing changed, so I've enabled it again) 1000169252.jpg
On the other hand, and unfortunately, my BIOS is a shame, just 2/3 options as you can see(I've also tried to disable SVM but nothing changed, so I've enabled it again)View attachment 8371
The BIOS Settings looks fine.
Disable EnableWriteUnprotector and enable RebuildAppleMemoryMap and then check. NootedRed still seems to be enabled.
Also, what macOS version are you trying to install?
With this options the installer doesn't even boot, KP while loading. I'm trying to install Sonoma.
EFI updated with last changes
EDIT:
I'VE MADE IT! I don't know if I can quote another site, but searching as "bootloop at 12 minutes remaining" I've found a similar laptop that introduced the UEFI driver OpenVariableRuntimeDxe.efi and it worked! I had to also put the SecurityBootMode to Disabled in order to complete the installation.
Now I'll try to enable again NootedRed kext to achieve graphics acceleration, there is something I've to change to enable it?
EDIT:
Sounds good!
But the modern hardware shouldn't require OpenVariableRuntimeDxe unless the NVRAM is completely borked. Since macOS Sonoma 14.5, the SecureBootModel must be set to Disabled to prevent bootloop during the installation/update phase.
Yes, you can follow the APU guide.
nnaa
