[AMD 4700u] Kernel Panic when booting installer
lucamania
AMD Ryzen 7 4700u
Hi everyone,
I'm trying to install MacOS Sonoma on an Asus Laptop (Vivobook S15 M533I with AMD 4700u) but even following step-by-step the video guide the installer won't boot.
This is the kernel panic (I think it's related to nootedred kext as you can see in the second and third screen, sorry for the image but it's a screenshot of a video because it reboots after showing for 1 sec the kernel panic):
I've also uploaded my EFI folder, where am I wrong?
Ty all.
Hi everyone,
Ty all.
That's right. Disable NootedRed.kext and then check.
Reactions: lucamania
Ok, now the installer boots but while installing (I've tried both online and offline versions) it reboots automatically without any type of error...any suggestion? I thought was the NVMe so I've inserted also the NVMeFix kext but without success.
Probably, kernel panic.
Attach a photo of the KP or a video of the verbose.
That's the problem...I've no KP on video :(
But I've recorded two trials, one while erasing the disk and one while installing the system...maybe you can understand what's wrong (I've already modified the EFI folder changing and reducing kexts, using SSDT from SSDTTtime but nothing)
Video 1
Video 2
Video 1
Video 2
Allow access to the files
Fixed, access granted.
Sorry for that
Just checked the first video. Your SSD is not compatible. Use a compatible SSD or install it on the same SSD but via external (using an enclosure).
alvarg82
