ASUS X556UQK sound and touchpad problem
Hi, can't paste iasl in /usr/bin. How can I do that ?
1. Go to Finder
2. Click on Go/Go to Folder
3. Type:
/usr/bin
4. Copy iasl compiler, which has been extracted and place it over here.
1. Go to Finder
3. Type:
/usr/bin
Yes, that's correct. What's the issue?
Can't drag it into bin, when Right click there is no paste item
Make sure you've copied iasl first.
Yes I did. Attach photo. It seems I don't have permission
Yes, no permissions. Make sure you're using Admin account. Is this a Vanilla install?
It's Catalina. How can I be sure my account is admin ?
Check User Accounts. On Catalina, you need to enable the write permissions.
It's says you don't have the necessary permission
raymondleung416
