It's ok now. It's the good file
IOReg is corrupt. Use v2.1.
Also, what macOS are you using?
I put two versions of IOReg in case it doesn't work.
I'm on macOS Sonoma 14.1.1
Ah. Sonoma does not have support for SKL GPUs. You'll need to use OCLP and perform root patch.
Thanks but you lost me there... can you guide me?
I’m on Intel UHD 630, on coffee lake ? It’s ok for this ?
And on OCLP i havent post root patchs update…
Ah, then it functions native. You don't need OCLP for that. Post the EFI+IOReg and also include System Information Report.
BTW, are you using DP or HDMI for the display?
All are there.
So I remind you: i5-9600k, MSI Z390 Tomahawk, UHD 630, macOS Sonoma 14.1.1
So I have two screens, the main one in DP and the second one in HDMI.
Currently I only use HDMI but if it's possible to use both that would be great.
All are there.
Ah, you've IGPU disabled. When you use -igfxvesa boot arg, it completely disables the framebuffer injection and enters vesa mode, therefore no kexts load which is the problem now.
Remove -igfxvesa and then check. You should have display via the DP.
xxxxxxxxxx
