AppleALC not giving any Audio Ports in macOS Sequoia.
strange huh? Try Fix HPET and then reset NVRAM once
I also Applied HPET. audio was working on Sonoma. Not working in Seqioua. Also my friend's audio is not working. Completely like me.
My sound didn't work at first either. But then it suddenly started working again. I also don't know why. Maybe you need to wait more. Oh, you didn't forget to add HPET's Patch to Config.plist, right?
Yeah I added HPET patch which was made by that .. forgot the name..
What did you really do? Give me your EFI. i need to analyze it
IRQ conflicts must be fixed, although not required on Desktop non-OEM boards. Also, try to check using different layout IDs.
I tried many layout IDs. also my friend updated to Seqouia. At first I used all the updated kexts and patches in his Sonoma. Everything worked. but WHen he upgraded to Seqouia, sound not working..
Try my AppleALC.kext. i dont remember what i do
Wait for an update!
  • Sad
Reactions: Sayor0603
fierofree
