Help with installer
The screenshot tells issue of CPU not being utilised.
Please attach your PR files.
Thanks a lot for your fast response.
What are PR files and where are them ? I'm not an expert unfortunately!!
No worries. PR files means Problem Reporting files. For now, your Clover folder is required. Read the FAQ thread for more information on how to attach your PR files.
Reactions: biglibigli
Also, check your inbox!
my clover attached
my clover attached
The drivers/UEFI is not upto the mark. These must be removed.
AppleKeyAggregator.efi
AppleKeyFeeder.efi
AptioMemoryFix-64.efi
FirmwareVolume.efi
PartitionDxe.efi
These are the missing drivers
SMCHelper.efi
FSInject.efi
Make sure you're using latest Clover bootloader. Enable verbose in the config.plist from the Boot tab.
Attach your verbose video.
yes I'm using latest clover 5093 from this forum. changes on drivers DONE.
for Enable verbose what I must add in arguments can't find it when right click on it ?
Yes, just select verbose checkbox from the boot tab in config.plist.
Find it, needed to add -v in boot args
Ok, I did all. Changes in drivers and config file.
Again the disk manager shown but apple logo and progress bar are above it with Transparency. So I can't do anything
my clover attached
My Situation with this clover config and drivers that I boot from USB installer. Can't open clover configurator to copy EFI folder in system EFI.
When I plug in a display (pci) system just restarted. I think it must be something with graphic driver
brigada_33
