Help with installer
You must attach all the files in a single zip file. The Clover folder is big. Check the FAQ thread to know how to attach your Clover files. Apple and Themes folder must be omitted.
thanks, here it is.
I edit last post and remove files.
thanks, here it is.
Check your drivers directory. Unnecessary drivers are installed.
Read the Clover Notes and remove the unnecessary drivers.
Remove FakeSMC sensors kexts.
Catalina requires EC. Enable the change EC0 to EC patch in config.plist from Acpi tab.
Reactions: biglibigli
ok, I did all exept this : Read the Clover Notes and remove the unnecessary drivers
couldn't find the Note you mentioned in github.com/CloverHackyColor/CloverBootloader, where I downloaded it.
can you give me the link
Well, i haven't mentioned the above link in the guide.
You can download the Clover Bootloader from the downloads section of this forum.
Ok, I got clover v2.5_r5083 from this forum and use last kext and driver and config.
Installer loaded but when I tried erase ssd drive with apfs GUID partition map it stuck for 2 hour now. (Attached image)
Should I wait more or force turn off system and try again ?
Samsung ssd 750 Evo 120gig with no partitions
I can't send clover log or check kext and driver that I placed in EFI until remove USB drive :( I don't get backup!!!
The latest release available on the forum is v5093. Use that one.
No PR files attached.
You can use Windows and send those files. For the moment, i need to check Clover folder.
I don't have windows in my laptop,
I retry and retry with same efi and finally I succeeded to install Catalina on ssd and load it. Clover config stuck on load efi menu to load efi folder so I couldn't replace USB efi folder in main drive. I restarted the system with usb plug in.
On first boot I realized some graphic problems . I checked system info and it says my graphic is Intel hdmi 620.
Now I stuck in this screen. One time it stopped on loading and again it show users but apple logo still show !!! Some time I can select user and enter pass but desktop wouldn't load
Can I get error log from clover boot menu ?
What should I do now ?
The screenshot tells issue of CPU not being utilised.
Please attach your PR files.
biff
