Stuck on ApplePS2Controller Catalina ( ASUS ExpertBook P3540FA )
2MB. xD
Disable RebuildAppleMemory and enable EnableWriteUnprotector and then check.
It's again stuck on:
ApplePS2Controller: Notification consumer published: ApplePS2Controller
ApplePS2Controller: Notification consumer published: ApplePS2Keyboard
Revert the Quirk.
Enable RebuildAppleMemoryMap and disable EnableWriteUnprotector. Also, disable SetupVirtualMap and then check.
Revert the Quirk.
Idk how to revert quirk so i try using default quirk settings of OC 1.0.0 and do the changes and the result is KP !
Enable SyncRuntimePermissions and then check.
The KP's still there. Is the problem comes from the BIOS settings or smth.
Well, in that case, attach your BIOS Settings. Take pictures, zip them in a single file or upload the photos directly.
Also, are you using some sort of bad USB or image? There have been cases like that.
I'm just switched to a new USB so maybe the issue comes from the new USB? And from the image i'm using macrecovery.py from OC packages.
Is common. Happened for a fellow member a few days back!
Re-download to ensure you're using a valid complete image. Delete the previous one, re-download.
kocsik
