NEED HELP FOR INTEL HD 4400 GRAPHICS
noobplayze
INTEL H81
Intel i3-4130 (4th gen processer)
INTEL HD 4400 IGPU
11.0.x
Dear Guys,
I need some quick help in resolving that issue
So i recently installed MacOs BIgSur on my pc with open core efi
every other issue solved except graphics acceleration
It showing me the ghraphic accerlation is 8 mb
Even i watched youtube solutions those are not working for me
So please find me a solution
also i am new here, so please tell me so simple so that i can understand
Here are my graphics spcifications:
Here are my os specifications
Also i wll post my mac system specs
Here is my Sys specs
Processor Intel(R) Core(TM) i3-4130 CPU @ 3.40GHz, 3400 Mhz, 2 Core(s), 4 Logical Processor(s)
Motherboard INTEL H81
RAM 4GB DDR3
GPU INTEL HD 4400
CONNECTION TYPE (VGA CABLE)
I have uploded my efi file pls check that out
Please answer me asap
BTW
Thank you :),
Hi, download hackintool or gfxutil in order to find out the name of your Intel (It looks like PCIRoot(0x0) etc.), just throw off a screenshot with the exhaust from one of these programs, and I'll explain how to register the factory
Dear Guys,
RAM 4GB DDR3
GPU INTEL HD 4400
BTW
Thank you :),
Your EFI is not as per the guide. No Framebuffers patched.
Are you asking my cpu's codename? , its "Haswell"
Is this enough or should i tell more details?
This photo of system info from Hacintool
Done creating EFI !
But When i Booted I encountered a problem
This Version Of MAC OS X is not spported on your system
Reasom: Mac-F2238ACB
(i uploaded EFI)
Done creating EFI !
(i uploaded EFI)
Use a newer SMBIOS which supports Big Sur.
I tried and encountered this error
IMacPro1,1
iMac14,4
iMac15,1
fot three of these same error
(updated efi)
IMacPro1,1
iMac14,4
iMac15,1
(updated efi)
The previous error was different and was an SMBIOS issue.
Enable EnableWriteUnprotector quirk and you should be able to boot.
xmax114
