You then need to use a compatible Graphics card. A budget option would be RX 480/RX560/570/580if gtx graphic not supported i install mac its work fine or laged
if not work with out graphic card
sonoma mac os work without graphic card please suggest best mid range graphic card for me
also noted i have not dedicated hdmi port in mother board i used gpu hdmi to display moniter
