asus rog strix gl10dh ryzen 7 2700 8core
Ashish123
asus
amd
nvidia
  1. OpenCore (Legacy)
i have ryzen 7 2700 8core
NVidia gtx 1650 4gb ddr 5
16 gb ram
512ssd nveme
i want to install macos in this pc please guide me macOS sonoma
1 have 1tb wd blue SSD sata also in this i have 2 partion 500gb of each
one of this i need to install macOS
i need to duel boot mac and windows
i watch this video and create efi and try to install i got error
oc failed
this is my efi file and pandrive screen shoot
  • EFI.zip
    EFI.zip
i want to install mac os in wd ssd this attach with sata cable and i want to make c as windows this is nveme
this is posible with dual boot
if any video please refer me for this
if you create me efi for my pc i do very well becuse i cant find my pc config with dual boot
whare i can get image of sonoma in video i cant find this how i put in pendrive plese guide me
My efi is ok or i made mistake somthing with my config
and i also know that this sonoma work well with my pc and all comonet grapic card work well
You were already provided with the video link!
my question is this work in my pc with all comonent work well
GTX1650Ti isn't supported on macOS. You'll need to replace the GPU with a macOS compatible AMD GPU.
i cretate bootable pendrive as per you website guide
i create bootable with rufuse as per guide and create mac os with python
python genrated folder com.apple somthing i put in pendrive and create efi also as per above i given i put also in pendrive
i also set csm disable in boot menu and also ser boot from pendrive
but its not boot from pendrive
its open by default windows 11
what is issue for this
if gtx graphic not supported i install mac its work fine or laged
if not work with out graphic card
sonoma mac os work without graphic card please suggest best mid range graphic card for me
also noted i have not dedicated hdmi port in mother board i used gpu hdmi to display moniter
Provide a picture of the OpenCore picker.
Zementos
