SOLVED Graphics Spoof not working (AMD Radeon R9 270X)
I think I found the reason why it doesn't work... In Hackintool, WITHOUT spoofing, the device id is 0x6810. What should I do then?
When you make the changes to the EFI, you should attach the PR files to check.
Oh sorry, I will give it tomorrow.
Anyways, I fixed the issue. (I removed the spoof and installed graphics with OCLP)
@EliteMacx86 I have a question, was that method correct?
Yes, for Legacy GPUs on the newer macOS, you'll need to use the OCLP. Not sure if you mentioned the macOS version you were using. Otherwise, could have recommended to use OCLP so much earlier. Anyways, glad its all solved now. Do you see the Graphics acceleration after patching with OCLP?
Reactions: phil_malt
I have macOS Sonoma. But can I turn AMFI back on after graphics patching?
FigureVR
