Does macos sonoma work on ryzen 4300u?
alfio95ita
hp 8707
Ryzen 3 4300u
Igpu vega 5
Hi everyone, I just followed this video (
) to try to put macos on my laptop, I followed all the steps in the video, the EFI check doesn't give any errors, but when I click install macos sonoma, support apple.com mac setup appears.
I'm new in this field if you have any tips to give me I'm happy
the laptop is a hp 15s-eqxxxxnl ryzen 3 4300u vega 5 renoir
Thanks in advance :)
Attach the picture of the issue.
the error is the first image but I playing a bit with the efi now it stops on exitbs as in the second image
  • EFI.zip
    EFI.zip
edit: I disable EnableWriteUnprotector and use RebuildAppleMemoryMap and the error of the first image appears
Do not use WhateverGreen and NootedRed together!
Also, use GenericUSBXHCI.kext (AMD).
ok I'll try now, thank you very much 🥹
I did as you said, I tried either only with nootedRed or only with WhateverGreen but nothing, same error
Could it be that Sonoma just doesn't work? Should I try an older system like Monterey?
Thanks in advance
I forgot to activate devirtualisemio and now it's stuck here
  • Wow
solved it started but the trackpad doesn't work
DevirtualiseMmio did the trick i guess.
Yes, the Trackpad won't work until you patch it. You'll need to use an external Mouse for the time being.
jkzql77089
