How To Fix AMD ryzen WiFi and Bluetooth On macOS Sonoma
deepak51015
HP laptop 15s-gr0011AUIN
AMD Ryzen 3 3250U
Vega 3
I recently installed Sonoma on my Ryzen laptop, but I'm encountering issues with some features. Specifically, Wi-Fi and Bluetooth aren't working, and I’m unable to adjust the screen brightness.
I’ve attached the efi:
  • EFI.zip
    EFI.zip
That's an unsupported Adapter. Replace it with a compatible Adapter instead.
Which adapter will be compatible for my laptop? And where can I get it
And I noticed one more thing, my touchpad is not working, only the mouse is working
You need to decide between Intel and Broadcom. Those are the only two which works to an extent, if not fully.
Off-topic. Either create a separate thread for each issue or create a dedicated thread to cover all the issues.
I have Realtek what should I have to do?
I watched your video and followed the steps, my Bluetooth got detected but WiFi is still not detected.
Seriously? Its same thing like you have AMD Graphics Card and trying to install NVIDIA Graphics Driver? Does that makes any sense at all? Not at all.
When you have Realtek WiFi Card, why do you think following the Broadcom WiFi Guide will make your WiFi/BT working? People wants to know, explain please.
because I can't find any files for realtek because I don't know anything about it
may be realtek rtl8821ce 802.11ac pcie adapter for hackintosh is not supported
what do you think ?
If you/anyone have any kexts file for this then please provide it to me
But does that mean following irrelevant guide will make it working?
jorgelreza
