FIX Problema con mi TRACKPAD (SOLVED)
tucoweb
kaby lake
Intel Core i3-7100U
Intel HD Graphics
  1. iMac Pro
  1. Other
Problem with my TRACKPAD, I have a Dell Inspiron 13 5378
I installed SONOMA 14.3.1 in my Dell Inspiron 13 5378, audio, Wi-Fi, touchscreen and Bluetooth work well and without any problems, what doesn't work and I can't understand how to solve it is the TRACKPAD, to use it I have to connect a mouse . Has anyone of you had this problem?
Thanks for your help and thanks for accepting me into the group.
have you put the Voodoo kexts in you EFI folder?
Depending on the Trackpad type, either PS/2 or I2C, install the appropriate kexts. If its I2C, patching might be required.
rbrb
